no start
no start
ok well i took everything off my engine on the top...the fuel rail took the injectors out....all the piping
now its all back in all the new connectors for injectors new spark wires cap n rotor...new connectors for air regulator, for thermotime switch and everything else...
i upgraded to bigger TB and a turbo AFM.....
now when i try to start...it turns over but wont start
how long does the fuel take up to fill the rail and evertyhing?
what should i check?
thx in advance
thx in advance
Guest
Posts: n/a
Generally, the three things that a car requires in order to start are:
Timing - make sure the timing's right. I can't imagine why you'd have to mess with this, so it ought to still be good.
Spark - Did you touch anything electrical? Make sure everything's connected properly and securely.
Fuel - I assume you hooked everything back up properly. Right? Is the system getting pressurized in the first place?
Maybe switching to the turbo housing requires you to mess with the flapper tension? (I would ask someone that did that swapt to be sure thought) I know when I switched to 370cc injectors my Z wouldn't crank over and just flooded till I leaned it out. Also check for any vacuum leaks by the throttle body. My friend had one on his 240sx, some how his gasket wasn't sealing 100%, replaced it and now it's fine.
John 82ZXT
John 82ZXT
I remember testing some stuff on my car once and I unplugged the AFM. The car still started and would idle but I couldn't hardly move the throttle at all before it would start to die. Maybe spray some starting fluid in there to get it to fire up a little and maybe once it idles once and is warmed up you'll have an easier time troubleshooting.
haha dumb me...i had the book facing wrong way when i hooked up my spark plugs...
anyways
my turbo AFM and my 60mm TB RUN GREAT
i adjusted the AFM using that pic ya gave me bleech...
runs better then it did before....
thx for all great help ill take a pic of my engine 2morrow and post it :P
anyways
hehe stupid me...anyways got her goin...heres a pic er two
really havin trouble attaching
i took most of stuff apart and sandblasted it and painted high heat aluminum paint..really turned out good i think...
Originally Posted by duckyz
Yeah...lookin' good! What's that filter lookin' thingy between the injector fan arms...a breather?
also a pic of my guages....the black area is way way less then it seems in the pic...
The gauges look cool. What kinda bulbs are you using to illuminate the gauges? I have a set of white face ones and I'd like to change the color as well, but I heard that regular blue bulbs aren't bright enough. Are you using LED's?
John 82ZXT
John 82ZXT
thx...
theyr just regular blue bulbs....just make sure you clean the old face (if using old faces) real damn good...sand it till its all white colour....back and front...sand sand sand....see the black thing there is the back of gages that i made a mistake of not sanding off..but i think it still looks good cuz when i look at it in the car...it seems only the numbers are lit really good and middle is darker...which is cool with me
bongpogi
Aug 19, 2015 11:15 AM
moorebl
Apr 14, 2011 03:28 PM
