Need some advice with injectors
Old Oct 12, 2010 | 09:34 PM
garretthes's Avatar
After finally getting the car to run I'm getting nothing from 3 of the injectors. I pulled the rail and inspected. Probably need to replace ALL the rubber. So here is what I have found:
Injector O Ring kit with 6 large and 6 small O rings
Injector holder (6)
However, I see a second option for injector O rings.
http://www.partsgeek.com/catalog/197..._seal_kit.html
In the FSM I see only 1 large and 1 small O ring.
It's just a little confusing and I want to get the order right the 1st time.
I plan to use high pressure fuel line for the hoses.
Also, I have a parts car and was planning on swapping out the bad injectors with the ones from it. How do I test them?
Thanks!
Old Oct 12, 2010 | 09:55 PM
Bluekitsune's test rig: https://www.zdriver.com/forums/showt...859#post280859
As for the "second option", you mean the pic w/ just two o-rings? I dunno what those are, but what you need is the set of 6 big flat o-rings, and 6 small flat o-rings.
Old Oct 12, 2010 | 09:57 PM
garretthes's Avatar
Yeah I saw those on two different websites. Thanks for the heads up.
Old Oct 17, 2010 | 12:24 AM
borini63's Avatar
I found my set in checkers auto parts.
But Bap auto parts will sell them with the injector tip cover.
Old Oct 17, 2010 | 09:42 AM
garretthes's Avatar
Yeah I noticed the covers are brittle and probably need changing. I'm going to use the injectors from the 83 because they are in better shape.
Old Nov 1, 2010 | 10:14 PM
garretthes's Avatar
Got everything in with new pintle caps and it seems to be running much better. No missing
thetremendousti
Aug 14, 2008 09:42 PM
asionboi23
May 21, 2008 05:30 AM
cake872
Oct 19, 2007 11:43 AM
Gofast
Mar 24, 2006 02:04 PM
zerodown765
Aug 29, 2002 10:34 AM
