Need some advice with injectors
After finally getting the car to run I'm getting nothing from 3 of the injectors. I pulled the rail and inspected. Probably need to replace ALL the rubber. So here is what I have found:
Injector O Ring kit with 6 large and 6 small O rings Injector holder (6) However, I see a second option for injector O rings. http://www.partsgeek.com/catalog/197..._seal_kit.html In the FSM I see only 1 large and 1 small O ring. It's just a little confusing and I want to get the order right the 1st time. I plan to use high pressure fuel line for the hoses. Also, I have a parts car and was planning on swapping out the bad injectors with the ones from it. How do I test them? Thanks! |
Bluekitsune's test rig: https://www.zdriver.com/forums/showt...859#post280859
As for the "second option", you mean the pic w/ just two o-rings? I dunno what those are, but what you need is the set of 6 big flat o-rings, and 6 small flat o-rings. |
Yeah I saw those on two different websites. Thanks for the heads up.
I found my set in checkers auto parts.
But Bap auto parts will sell them with the injector tip cover. |
Originally Posted by borini63
(Post 286342)
Got everything in with new pintle caps and it seems to be running much better. No missing
