need help with injector replacing
Old Oct 26, 2010 | 04:01 AM
modrod's Avatar
I have a 1983 ZX non turbo. I am needing to replace the fuel injector that is closet to the firewall. Do I need to remove the fuel rail to replace the injector? Any advice will be greatly appreciated. Thank you.
Old Oct 26, 2010 | 06:40 AM
skib's Avatar
This facepalm's for you!
its gong to be easiest to pull the fuel rail.
if youve never done it its going to seem like a pain in the ***.
but after a few times it dosent seem that bad....
but then you realize that it is a pain in the ***! so you get a billet fuel rail instead
and never have to deal with the pita again
Old Oct 26, 2010 | 04:35 PM
zfreak1981's Avatar
280zx
Mine was pretty simple. I didnt pull the fuel rail compleatly off either.
Old Oct 26, 2010 | 10:16 PM
modrod's Avatar
pulling the fuel rail
Any recommendations as to how to go about pulling the fuel rail off.
Any and all advice would be greatly appreciated.
thanks
Old Oct 27, 2010 | 03:09 AM
WanganDevilZ's Avatar
The Emblem Thief y0!
thanks
Unbolt it.
Make sure you have no flammable objects nearby, as gasoline WILL come from the injector feed line >.> (Wear gloves if you have any cuts or open sores, this brings foul language down to the bare minimum, use a shop towel to collect/mop up spilled gasoline)
Not sure how many bolts are holding it on, I remember it didn't take me long to get it off and put it back on without the FSM.
Old Oct 27, 2010 | 08:33 AM
audiofreak97's Avatar
Oh yeah?! Freak this!!!
+1 on this...
Remember to de-pressureize the system before pulling a fuel line
And, If I'm remembering right, there is a bolt on the passenger side of the engine, take off the top belt pulley on the front of the engine, two bolts on the intake manifold and the 2 screws on each injector... then it should come out with very little fight... unless I'm forgetting a bolt somewhere...
Old Oct 27, 2010 | 02:16 PM
+ 2 on that one man. It makes it so much easier, after putting an aftermarket fuel rail on. Less headache, and smoother operation.
Stinvil
Aug 28, 2011 11:42 PM
zcrazy13
Aug 1, 2011 07:01 PM
soxandfloyd1969
Jun 23, 2009 01:23 PM
b300z
30
Aug 15, 2005 09:00 PM
assimilated420
Apr 13, 2005 01:42 PM
