need help with injector replacing
I have a 1983 ZX non turbo. I am needing to replace the fuel injector that is closet to the firewall. Do I need to remove the fuel rail to replace the injector? Any advice will be greatly appreciated. Thank you.
its gong to be easiest to pull the fuel rail.
if youve never done it its going to seem like a pain in the ass. but after a few times it dosent seem that bad.... but then you realize that it is a pain in the ass! so you get a billet fuel rail instead :082: and never have to deal with the pita again :042: |
280zx
Mine was pretty simple. I didnt pull the fuel rail compleatly off either.
pulling the fuel rail
Any recommendations as to how to go about pulling the fuel rail off.
Any and all advice would be greatly appreciated. thanks |
Originally Posted by modrod
(Post 286677)
Any and all advice would be greatly appreciated. thanks Make sure you have no flammable objects nearby, as gasoline WILL come from the injector feed line >.> (Wear gloves if you have any cuts or open sores, this brings foul language down to the bare minimum, use a shop towel to collect/mop up spilled gasoline) Not sure how many bolts are holding it on, I remember it didn't take me long to get it off and put it back on without the FSM. :023: |
Originally Posted by skib
(Post 286648)
and never have to deal with the pita again :042: Remember to de-pressureize the system before pulling a fuel line :wink: And, If I'm remembering right, there is a bolt on the passenger side of the engine, take off the top belt pulley on the front of the engine, two bolts on the intake manifold and the 2 screws on each injector... then it should come out with very little fight... unless I'm forgetting a bolt somewhere... |
(Post 286648)
