need help with ignition problem
Old Sep 2, 2007 | 04:04 PM
zstreet86's Avatar
ok, everything was sparking fine just a couple weeks ago before i pulled the injectors... after i put everything back, now i dont have spark. i know the ignition coil has power on both sides, but it doesnt spark from the coil to the distributor. i was thinking maybe the crankshaft position sensor, which is inside the distributor, or the power transistor next to the coil? does anyone know of a way to test these. i had no luck with the haynes manual on this one. im stuck and need some help. thanks in advance.
Old Sep 2, 2007 | 06:43 PM
zstreet86's Avatar
by the way this is for an 83 280zxt
Old Sep 2, 2007 | 06:57 PM
Is the coil and bracket securely grounded? It won't spark if it's not grounded.
Old Sep 4, 2007 | 08:05 AM
check the plugs on the distributor. Make sure the round plug is in secure. That is for the crank angle sensor you mentioned.
Old Sep 4, 2007 | 08:07 AM
zstreet86's Avatar
yeah its posssible that the coil is loose, ill check it later today and let you guys know what happens. thanks
Old Sep 4, 2007 | 06:28 PM
zstreet86's Avatar
the coil was way loose, but no dice even after i tightened it up. luckily i caught the problem: a loose connection on the top of the motor. she fired right up, unfortunately ran like crap, but at least finally she's running and staying running.
its really rough and lots of backfiring, no way is the car even close to drivable, in fact i doubt i can put it in drive without it stalling. but at least i am making progress.
thanks for all the help in all of my threads, most especially to you nismopick. i wish i had a junker near by to swap parts with... oh well i just wanted to let some of it out, talk to you guys later!!
Old Sep 5, 2007 | 07:08 PM
Check your spark plug tips & timing now...
Old Sep 5, 2007 | 07:14 PM
zstreet86's Avatar
thanks nismopick, thats actually the next thing i was going to check. however i wont get around to it till next week becasue i have a big test on friday, and im leaving town this weekend... school sucks lol
Old Sep 29, 2007 | 06:32 PM
palladin21's Avatar
your spark problem.
My ZX developed a miss. I thought it was the plugs, but no. What it was, was that some yoyo I bought it from did not insert the dist plug wire all the way in and it began to fire through the bakelite.
Old May 17, 2008 | 04:09 AM
harmonics's Avatar
hi i have a 83 zx turbo that wont start i've tested ecu.changed distributor.the car will start if i ground the injectors at the ecu if anyone have any suggestions i would be very gratefull thanks
Old May 17, 2008 | 12:25 PM
zstreet86's Avatar
when's the last time it ran?
Silv3rstar
Mar 8, 2013 06:34 AM
2.8.0.Z.X
Jun 17, 2009 01:04 PM
my1990300zx
Oct 11, 2007 04:58 PM
sosome
Jun 26, 2002 05:04 PM
