Need Dizzy help
Old Jul 4, 2006 | 08:37 AM
  #26
Originally Posted by TX_zx
Ok Poo, Im going to sound like a dummy here, but where is the ecu? My particular book is no help at all.( chiltons )not in the index. any help, thanks
All 280zx's have the ecu under the drivers side kick panel. It lookie like this:
Old Jul 4, 2006 | 03:39 PM
  #27
TX_zx's Avatar
Thanks Nismo,
Pretty sure I can find that.
Mark
Old Jul 15, 2006 | 12:35 AM
  #28
80greystang's Avatar
Mark,
I don't know if you are still trying to get it started. Since it looks as though 6 weeks has passed.
I am currently rebuilding my daughter's 81 280zx NA, and we have a spare ECU if you want to try it. I think the '81 ECU will work in an '83 if the engine is an L28E.
I am up in Cedar Park (just above Austin) if you want to give it a try. Send me a message and I'll give you my contact information, and details on how to get up here.
Old Jul 15, 2006 | 11:03 PM
  #29
EatmyDust's Avatar
thats a bit extreem, for a no fire problem. I don't think it will be the ECU, as the computer dosn,t have to do with firing. it would be more along the lines of ignition module.
Old Jul 16, 2006 | 10:07 AM
  #30
You're kinda right... it does sound more like an ignition prob, but the ecu DOES send the original signal to the coil to spark.
Old Jul 16, 2006 | 11:11 AM
  #31
TX_zx's Avatar
yea just to let you guys know Im still here. Tried wiggleing the connections. Even took the ecu off and apart to see if I see noticeable burnt parts on the board, nothing yet, going around with ohm meter..Nothing ventured, nothing gained.
Im still listening
Mark
Old Jul 16, 2006 | 11:53 AM
  #32
datsunl28et's Avatar
Hey underneath the distributor by the conector is that lil black wire that hucks up to a prong on the distributor shaft make sure that is connected cause that problem happened to me before the wire came off and I had nothing, my friend saw it and asked why it was disconnected and I put it on the prong and it fired right up. just a thought though....
Old Jul 16, 2006 | 12:16 PM
  #33
EatmyDust's Avatar
that little balck box is the ignition module.
Old Jul 17, 2006 | 01:59 PM
  #34
TX_zx's Avatar
Just to let yall know, I did find 1 resistor bad, 1 diode bad, and 1 IC bad, these are all cheap parts,,I will replace them here soon and see what happens. better than 200$ with a 90$ core !?
Mark
Old Jul 17, 2006 | 02:01 PM
  #35
PooFlinginMonke's Avatar
So the Zener diode on the power circuit was toast?
If it happened on your car, I would check to see if anything that operates off of Vref could be shorted to ground.....possibly intermittently.
Old Jul 17, 2006 | 05:13 PM
  #36
TX_zx's Avatar
Yea I was thinking that also, but it coulda happened when my my dizzy first fried, bearing went out sending the shaft ****-eyed takeing the stator, pick up magnet and well pretty much exploded the insides, also Im not much of a fan of the digital dashs..There is a short some where, kinda always had gremlins in there. No telling,,ill keep updateing
Mark
Old Jul 21, 2006 | 07:04 AM
  #37
Dang that is harsh.
Haven't seen one do that since the mid 80s camrys.
Old Jul 21, 2006 | 10:00 AM
  #38
bradz240's Avatar
Have you tested the ignition module to see if it is ok. My mechanic friend has a tester for them. That's what it has always been on mine when it wouldn't fire. I pick them up form the junkyard whenever I find them to keep for a spare.
Brad
Old Jul 21, 2006 | 10:03 AM
  #39
bradz240's Avatar
Also early models IM's are different from the "83's.
zordietrying
Oct 21, 2014 09:54 PM
71OLDS
Jun 6, 2012 02:57 AM
zlaxbro
May 25, 2012 03:30 AM
WildmaN
Jun 8, 2005 03:03 PM
