More blow off valve help
Old Sep 24, 2005 | 05:48 PM
Blue280zxTurbo's Avatar
ok so now i know that i have to weld it onto the j pipe. but do i need to do anything with the stock emergency relief valve? where is the vaccum line that i need to hook up to the blow off valve?
thanks guys
Old Sep 24, 2005 | 06:14 PM
the emergency release valve isn't a bov. all it does, is open (sounds like a dying squirrel) at about 8 psi. It's a backup incase the wastegate malfunctions... meaning @ stock boost it won't open. If you up the boost, then you will need to cap it, or buy the upgrade ($100) from MSA.
There is no set vacuum line for it, since the factory never put one on. Just use a vacuum hose T in one of the manifold lines.
Old Sep 25, 2005 | 03:53 AM
tickwon's Avatar
Yeah, I T'd mine off the vacuum line off the fuel pressure regulator.
Old Oct 22, 2005 | 11:50 PM
nismo619's Avatar
I have got a boost controller from scl30 and yes the boost controller really does work but u must seriosuly CAP OFF or buy a New MSA one or go to www.zcarparts.com personaly im gonna try and modify my own POV by my self DREMEL and DRILL hear i come !!! hehehe
Old Oct 23, 2005 | 09:40 AM
s/cL3.0's Avatar
Bleach is my Hero
I am just going to remove mine and cap it when the time comes [not weld]
turboZ87.300
20
Apr 15, 2009 07:30 PM
hchase17
Mar 16, 2009 07:46 PM
Oxide
Mar 1, 2006 09:37 AM
haktmal
Apr 20, 2003 06:59 PM
lil_racer_tony
Aug 27, 2002 11:19 PM
