MAF placement
Old Oct 22, 2013 | 11:37 PM
zordietrying's Avatar
MAF placement
I'm installing an intercooler, so I have to pipe my air filter and MAF differently. My filter will be under head light bucket and intake pipes going through inner fender to turbo. I have 2 options.
1. Should I place the MAF directly on filter then pipes through inner fender to turbo. This will place MAF under head light bucket along with the filter.
2. Should I run filter then a 45 coupler through inner fender then to MAF then pipe to turbo.
Now why I ask this is because this means the MAF is either right on the air filter or after a 45. Both of which I have heard is not good.
Old Oct 23, 2013 | 07:56 AM
Does your IC have some funky in & out? Pics of your IC?
Just wondering why you are going through the wheel well rather than radiator support...
Old Oct 23, 2013 | 11:29 PM
I'll have to post some pics when I get it in. Its just a vertical IC with inlet and outlet on the same side so that means that two 2.5 inch pipes have to go through the same side of the radiator support no room to have another 3 inch pipe for the filter. I could run the filter after the radiator in the engine compartment but that isn't very efficient. So best option is to run the filter out through the inner fender.
Old Oct 25, 2013 | 03:11 PM
You want a straight shot for the MAF - turbulant air will cause you problems especially at idle. Of the two poor options right after the filter is best.
Old Oct 25, 2013 | 08:03 PM
That's how I ran it. It turned out really good. But if I can make room, whats the minimum length of pipe that should be between filter and MAF?
Old Jan 15, 2014 | 07:45 PM
Just a note for other guys doing custom intakes don't put air filter directly on the MAF. Runs like crap and very jumpy at cruising speed.
Old Jan 16, 2014 | 08:25 PM
As I said turbulent air will cause problems with your MAF. If you attach the air filter to the MAF you may not have enough of a run to smooth the air out. You need a section of pipe - preferably straight - before the MAF to make sure the air is metered properly.
tguarino
Feb 24, 2014 06:40 PM
LikeZcars
May 29, 2011 12:36 AM
Drax240z
Aug 1, 2001 09:04 PM
demented69
Apr 27, 2001 04:01 PM
