j30/z32 vlsd in 280ZX?
Old Jan 5, 2007 | 12:43 AM
rxKaffee's Avatar
What would it take to put a j30 or z32 vlsd into my 280ZX? Would I mount the entire unit to my subframe, or just transfer the internals into my stock case? I have a 10mm R200 currently.
From what I've seen about putting z31 lsd in, I believe I would only use the j30/z32 internals.
Thanks, rxKaffee
Old Jan 5, 2007 | 01:38 AM
thxone's Avatar
I too believe that to be true...internals only.
Old Jan 5, 2007 | 07:38 AM
You might be able to transfer the carrier only if the bearing size is the same, but you still have to use the J30 cv shafts, as it has a different spline count than that 280zx R200. Which means you'll have to make adapters to connect the J30 cv's to your 280zx hubs... if they are even close to the same length. Some people have done it, but it takes enough $$$ and time, that it's easier to just find & swap in a Z31T LSD.
Old Jan 9, 2007 | 07:03 PM
rxKaffee's Avatar
Which bearing do you mean? I'm wanting to swap, both for the j30/z32's larger capacity for cooling, and so that I can put a Kaaz unit in at a later date.
I would also like to swap to a 5lug setup in the rear, but haven't looked ath info on that recently enough to know how it will affect cv and spline stuff.
I've looked for some z31T parts, but they've been very difficult to locate, even for parts in not such high demand as the LSD.
Old Jan 9, 2007 | 07:22 PM
The carrier bearings.... they look like this:
One on each side of the carrier.
The differential doesn't have anything to do w/ a 5lug swap... You change the hubs to do a 5lug swap.
If you want an LSD diff, you have more than just the Z31 LSD option.
You can buy a Powerbrute for $550 ( http://www.precisiongear.com/powerbrute.htm )
Nismo makes one for about $750
Quaife makes one for about $1700
They might not be as cheap as what you could get the J30 diff for, but it's much less time consuming, nerve racking, realistic, & possible.
Old Sep 22, 2007 | 01:25 AM
rxKaffee's Avatar
That first one would be a nice catch at 550$ ! I don't think they make that for my car though? I have an `83 n/a 5spd, and as I understand it, it has the r200 w/ 12mm bolts inside as opposed to the 10mm bolts, and these aren't interchangable? LOM59-12 Is the closest part I could find, but it is for 10mm.
rx
Old Sep 22, 2007 | 04:54 AM
xenonxiii's Avatar
This May be of Help
http://www.xenonz31.com/Modification...d_install.html
Old May 15, 2008 | 09:48 PM
Lisa-Adam's Avatar
hey guys i bought a maf from ebay, i just wanted to make sure it was a Z32/J30 maf.ill be getting pics up soon but heres what it reads on the side
Old May 15, 2008 | 10:33 PM
lifegrddude's Avatar
Externally Wastegated
If you're talking about the Z32 maf, it should be an orange sticker with 3p000 or something like that on there. I believe N62 should be on there as well. If the sticker is yellow, that's the Q45 maf and not the right one. Those read N60 or some other letter/number combo.
Mitsu86t
Jun 5, 2013 10:00 AM
oldjdmskool
FS: 300ZX (84-89)
Sep 8, 2012 08:19 PM
BlueKitsune
Aug 28, 2011 10:45 PM
74260zt
Apr 28, 2003 07:07 PM
