Fuel Problem
Old Apr 14, 2003 | 09:15 AM
If you bypassed it, how did you do that?
That sensor changes ohms to the fuel injection computer based on the engine temperature. If you are bypassing it, you should run it through an ohm meter (simple volume control) and adjust it down more. That should get it to lean out more.
Also, check your fuel pressure if possible. I think it should be in the 40psi range. If its too high, then replace the fuel presure regulator. You can get those online for about $30 or so.
expressautoparts.com
Old Apr 15, 2003 | 12:11 AM
lifegrddude's Avatar
Externally Wastegated
How are the injectors themselves? If the they are getting old, the pintle might not be closing all the way during the "down" time of the injector and that could be soaking your plugs.... Just a thought.
John
Old Apr 15, 2003 | 09:30 AM
Because of the fact that you modified the temp sensor, I would look there first for your solution. Maybe just invest in a replacement from Nissan and hook it back up.
Grizzlyadams17
Nov 7, 2013 03:10 PM
soates4
May 22, 2013 06:43 AM
rupert42
Aug 15, 2004 06:08 PM
MasonVonRitchie
Aug 3, 2004 04:10 PM
ReVg30De
Jul 10, 2003 12:54 PM
