exhause manifold glowing...
Old Sep 23, 2006 | 12:06 AM
chinesekid's Avatar
hey quick question.... does/is your manifold suppose to be glowing?!?! i was driving for like 15 mins and i stop by my friends house and i pop up my hood and saw that my exhause manifold was glowing... is that suppose to be normal??? my car is an n/a.... so if you guys know anything.. thanks
Old Sep 23, 2006 | 12:19 AM
they can glow after some hard driving...usually noticble at night....but i dont think mine ever glew when i drove my NA. but there is an awful lot of heat coming out of there into those pipes.
Old Sep 23, 2006 | 04:05 AM
tickwon's Avatar
My understanding it might be a lean mixture, correct if I'm wrong. My turbo and manifold was glowing red one day...look pretty cool, wish I had a camera at the time.
Old Sep 23, 2006 | 08:56 AM
RodMoyes's Avatar
Doesn't post much...
Yeah, you might be running too lean... No Bueno! Make sure all your fuel goodies are working right.
Rod.
Old Sep 23, 2006 | 09:45 AM
check your timing as well, if its off its just as bad as a lean condition
Old Sep 23, 2006 | 09:46 AM
yeah... getting a cast iron manifold to glow takes some work! A lot of those vids showing a glowing manifold, are stainless steel turbo manifolds.... they are glowing from sheer heat & backpressure.
Deffinately check your a/f ratio, and make sure your exhaust is flowing correctly. Did the engine heat up when you were driving?
Old Sep 23, 2006 | 10:30 AM
RodMoyes's Avatar
I saw the exhaust manifold on my old SAAB 900 Turbo SPG glow once... ONCE!
That was the end of that car...
Rod.
Old Sep 23, 2006 | 01:44 PM
nismo619's Avatar
possable cloged or partiually cloged catalistic converter would cause that manafold to turn red also.. i saw it on one of my friends old ford cars..
Old Sep 24, 2006 | 09:37 AM
chinesekid's Avatar
everything was good but that... car temp was good. timing is good... could it be maybe a clog cat? buliding to much back pressure?
Old Sep 24, 2006 | 10:37 AM
thxone's Avatar
I crossed some plug wires on a friends '78 Camaro once and almost the entire right side exahust was glowing like the sun, it would pop a little bit under acceleraton but we did not really notice a big performance loss....just a thought to check those wires.
Old Oct 2, 2006 | 08:42 PM
EatmyDust's Avatar
dose it fill like your car is choeking, or lack powere and can't make it over a certain speed?
noelawinslow
May 21, 2013 01:17 AM
s/cL3.0
Sep 23, 2008 08:39 AM
ArizonaZ
Jan 26, 2008 07:21 PM
wreckedj30
Jan 7, 2007 09:57 PM
ThermalWake
Oct 10, 2006 07:07 PM
