Engine light... "Water"?
Old 03-19-2003, 02:41 PM
no, the sensor is in the overflow bottle, not the radiator itself. The sensor is activated by the thick ring that floats on the shaft. If there is enough fluid in there to keep it off the metal stop at the bottom then you won't see the warning. Just put some water in the overflow bottle. My bottle has a small leak in it, but the radiator is new. I just see the error all the time and ignore it.
If I wanted to fix it, I could rig up a custom overflow bottle.
Bleach is offline
Old 03-19-2003, 04:02 PM
Skully's Avatar
my check thing dont even work ......
Skully is offline
Old 03-21-2003, 12:46 AM
Externally Wastegated
lifegrddude's Avatar
It's probably a faulty sender. I had the same thing except for my windshield washer reservoir. Kept saying it was empty, but the thing was full! I think you just need to replace it, that's all.
John 82ZXT
lifegrddude is offline
Old 04-01-2003, 12:05 PM
Skully's Avatar
possibly mine doesnt light up either.....
Skully is offline
Old 04-01-2003, 01:36 PM
Ya, mine is all red when there is at least one fault. Then I press the button and it tells me what the problem items are. If you press the button and it stays red then something else is broken.
Bleach is offline
Old 04-08-2003, 02:46 PM
Skully's Avatar
LOL i jus pluged my guages and i get the WASHER crap....and HEAD LIGHTS......because one of my headlights is dim....and when i change to high beams....it goes even dimmer.......any ideas?
Skully is offline
Old 04-19-2003, 10:21 AM
Skully's Avatar
figured out the headlight problem...seems theres a fuse for EACH headlight......if i take one fuse out......right HL gets dim...and with high beams even dimmer......if i take the other one out and put the first one in....the other one gets dimm and dimmer with high beams on... i didnt know there was 2 fuses for each light!!
Skully is offline
Old 12-13-2004, 12:12 PM
VenomousZX's Avatar
ok, but what about the Battery light? I have the "Water" & "Battery" ones that go off, how do I address that issue?
VenomousZX is offline
TheShanMan
03-08-2014 03:25 PM
ananimator
12-17-2009 04:50 PM
inqui-Z-tor
10-10-2006 06:46 PM
topdoggcarlos
12-23-2004 06:55 AM
duckyz
08-10-2004 07:53 PM
Quick Reply: Engine light... "Water"?
