Cruise Control
Old Aug 31, 2009 | 07:19 AM
stiletto660's Avatar
Cruise Control
Hello Everyone,
I have a quick question about the Cruise Control on my 1980 ZX.
My speedo cable is hanging up at times, the needle on the MPH gauge pulsates up to about 40-43 MPH anything above that the needle will peg at either 0 or 80 MPH. My question is can this symptom be one of the reasons why my cruise is not working? I realize that there are several other things that I will need to check ie. Vacuum & Electrical componets but am not sure if the speedo cable can effect the cruise control operation? I have all ready replaceded all the little round pads on the brake and clutch arms that engage & disengage the switches, tested the cruise control main switch, turn signal/cruise control switch on the column. I still need to look at the relay and controller unit under the passange seat and the vacuum soleniods in the engine compartment.
Any other suggestions?
Thanks,
Phil
Old Aug 31, 2009 | 09:22 AM
Indeed, a jumping speedo could cause cruise control not to function properly. A jumping speedo is usually a kinked cable, dying speedo, maybe the speedo cog in the tranny is loose / stripped, maybe the cable just needs some grease. You'll never know until you tear into it.
Start w/ the basics.
Old Aug 31, 2009 | 09:49 AM
Thanks Nismo,
I appreciate the response Speedo Cog in the Tranny is fine, I'm going to check the short speedo cable for kinks I have a new spare if needed.
Old Aug 31, 2009 | 04:00 PM
Niku-Sama's Avatar
eff good grammar
mine used to wobble a bit, pulling in the cable from the engine side of the firewall and taking up the slack seemed to help for some reason
cblevons
Aug 21, 2005 01:44 PM
akshon_muZik
May 18, 2005 09:36 PM
Carl's Z
Feb 16, 2004 08:04 PM
kd5izq
Oct 8, 2002 04:06 PM
DMT84T
Jan 3, 2002 09:04 PM
