crank sensor
Old Mar 22, 2008 | 10:39 PM
seanzzy's Avatar
crank sensor
i need to know where the crank sensor and the timing marker bolt on in an 81 280zxt
sean.
Old Mar 22, 2008 | 10:46 PM
crank sensor is deep within the dizzy...
Old Mar 22, 2008 | 11:11 PM
Not on the 81...
The CAS on the 81 is on the drivers side of the crank pulley.
Old Mar 22, 2008 | 11:15 PM
Not on the 81...
who in the right mind uses the stock CAS system? and i never had that on my 81...
Old Mar 23, 2008 | 12:14 AM
81 turbo did. i hear its junk
Old Mar 24, 2008 | 09:10 PM
seanzzy's Avatar
alright i got that on and all my other sensor's and vacuum lines on and when i try to start the car its still showing the sensor light. any ideas?
Old Mar 24, 2008 | 10:03 PM
The yellowish orange sensor light? uh oh....
Oh wait... that's just the O2 sensor warning that lights up @ something like 30k miles. Then you take it to Nissan, they reach their lil hand under your dash and unplug a wire.
Don't worry about it... that isn't keeping your car from starting. Or did the car start? (you didn't say it did or didn't).
Old Mar 25, 2008 | 03:07 PM
seanzzy's Avatar
no it wont start. i tested the injectors and the sensor's that go on there and everythings good. probably vacuum somewere but i dont know. it could possibly be off time also but im pretty certain i have it right.
Old Mar 25, 2008 | 03:33 PM
you got spark yes?
Old Mar 26, 2008 | 06:50 PM
seanzzy's Avatar
yea i have spark
Old Mar 26, 2008 | 07:13 PM
Are your injectors spraying fuel?
Old Mar 27, 2008 | 02:35 PM
seanzzy's Avatar
yea they should be. i put on a new pallnet fuel rail and did a test on the sensor's that plug into the injectors.
Old Mar 27, 2008 | 03:23 PM
you could pull the rail with injectors still attatched and actually LOOK to see if they are spraying.
Old Mar 27, 2008 | 04:05 PM
Or just pull the spark plugs and look at the tips.
Old Mar 27, 2008 | 05:05 PM
seanzzy's Avatar
ll try that but they should be spraying there the same injectors i had on before
Old Mar 27, 2008 | 05:10 PM
not as effective imho. not like pulling the rail and cranking it is hard lol
That means nothing if the problem is electrical. And how do you know you have fuel?
Old Mar 27, 2008 | 05:39 PM
seanzzy's Avatar
well, i guess i don't. ill go check it out.
jturbo06
Dec 28, 2010 09:11 PM
oakleyp2
Apr 17, 2006 08:27 AM
firefighter1179
Oct 16, 2005 09:39 PM
jhayes169
Jan 22, 2004 11:19 PM
oni_roh86t
Oct 1, 2003 06:14 AM
