Car dies when i give it gas?
Old May 22, 2009 | 01:29 PM
midwest83280z's Avatar
Recently i tossed a 83 turbo in my 280zx and now whenever I give it any kind of gas it just sputters and dies. The car starts up and idles just fine...
Also.. when i had my old 81 ecu in it the car would die almost instantly if i pulled the afm harness, but now since replacing it with the 83 i can remove it and it continues to idle just fine with a slight stutter when i pull it.
My current setup is all stock, engine from a 81 280zx turbo, 83 dizzy and i'm currently using a 81 harness that has the resistor pack thats bypassed.
I searched for awhile on my wire harness schematics and really didn't see anything different between the 81 harness and the 83 ecu, especially with the afm wiring.
i'm confounded here.
Old May 22, 2009 | 02:02 PM
I would prefer to put this in your other trouble shooting threads to we don't have to re-live what was already mentioned.
But here we go with the basics:
-Have you checked the timing? What is it set to?
-Have you adjusted / calibrated the TPS?
-Have you checked the fuel pressure?
-Have you adjusted the AFM?
-Have you cleaned all sensor connections?
-Have you wiggled the ecu plug wires?
-Have you checked the spark plug tips to see if they are all the same? Wet? Dry? Color?
IF all that DOES check out... I would suspect something w/ your rigged dizzy or bypassed resistors.
Old May 22, 2009 | 02:24 PM
Rigged dizzy? Relive?
Wonderful response.
Old May 22, 2009 | 02:27 PM
^^^ And that was a good response to all my "check" questions.
Would you call the 83 dizzy on an 81 harness "not rigged" ?
Old May 27, 2009 | 09:30 PM
hchase17's Avatar
lol maybe modified instead of rigged...depends on how it looks haha
carpanz
Mar 22, 2007 03:55 PM
Coolie
Feb 11, 2007 07:48 PM
entropy31
Jul 24, 2006 07:17 AM
Cardoo
Jul 24, 2002 07:54 PM
