BOV recirculation question
Old Apr 24, 2006 | 12:31 PM
Heat Rave R's Avatar
I know that when installing a BOV, I should recirculate the release back into the intake, before the turbo, due to a metering issue. My question is, does it matter if I recirculate *before* the AFM (ie near the filter box), or *after* the ARM (ie the plastic tubing between the AFM and turbo? If it has to go after the AFM, does anybody have any ideas how to connect the 1" hosing to that plastic tubing?
Old Apr 24, 2006 | 12:58 PM
You don't absolutely NEED to recirc it. It creates a slight rich condition when opening as the ecu has already calculated that air... but I run mine open to atmosphere & it still runs great.
If you are going to recirc it, you must connect it back in AFTER the AFM, but BEFORE the turbo. So you will need to connect it back into that rubber boot connecting the AFM to turbo. I did that the first time & I used a copper fitting & cut a hole in that boot to feed it back in. Use some of ya engineering skillz!
Old Apr 24, 2006 | 01:32 PM
nismo619's Avatar
nismo pick do u have any used BOV ? just wondering if u would sell a used one if u had one...
Old Apr 24, 2006 | 02:22 PM
I have a spare DSM BOV, but I'm keepin it for another turbo project. You can buy BOV's for cheap on ebay now a days. Like this one:
http://cgi.ebay.com/ebaymotors/Turbo...58353019QQrdZ1
Old Apr 24, 2006 | 07:33 PM
nismo619's Avatar
Nismo pick u know me i cant use one like that.. how about this one ? http://cgi.ebay.com/ws/eBayISAPI.dll...DME:L:RTQ:US:1
u know.. i can wear payless shoes but i cant use nothing else on my car but brand name.. but honestly what do u think about this one ?
Old Apr 24, 2006 | 07:40 PM
uh... TurboXS is becoming quite popular these days:
http://www.turboxs.com/
If you really gotta have the BLITZ BOV, go for it! They are sweet BOV's!
Old Apr 25, 2006 | 12:25 AM
I thought of installing a fitting in the plastic/rubber tubing, but I was concerned the material wasn't thick/solid enough to securely screw in anything without eventually tearing loose. Heh, with gas prices so expensive, I don't want to waste all my gas everytime I blow-off!
Old Apr 25, 2006 | 08:18 AM
jfairladyz's Avatar
Nismo619, that Blitz BOV isnt going to have any benefit over the Turbo XS one. Like Nismopick said, they're not a generic brand. And with the TurboXS BOV atleast you'd be getting something new. A new Blitz BOV is going to be rediculously priced compared to the TurboXS.
HeatRave, when you screw the tubing into the intake hose use an expoxy or some sort of sealer/adhesive to secure the pipe.
Bruno Figarola
Oct 2, 2014 07:30 PM
Niku-Sama
Other Cars
Jun 24, 2011 10:25 PM
domsgarage
Oct 11, 2010 07:44 PM
