83zxt backfire in intake??
Old Aug 26, 2013 | 03:46 PM
7d82adz's Avatar
my 83zxt was sitting since last year.. parked with a problem of barely being able to run or rev up..
ive replaced the connector on the chts and cleaned that sensor. seems good.
plugs are carboned up, those r clean now and runs a tad better but still can barely move itself..
im thinking mass flow air sensor or something.. the car seems like it cant breathe and is choking out.
ive got a couple 280z's a 77 and a 78, and a 75.
the 77 ran last year but needs fuel pump and is a parts car anyways..
could the airflow meter off the 77 work on the 83?
thats my big question.
Old Aug 27, 2013 | 02:02 PM
#1: What's the timing set to?
#2: How old is the gas?
#3: Have you done all sensor (ohm) checks outlined in the FSM?
#4: No, a non-turbo AFM is not compatible with a turbo.
Old Aug 27, 2013 | 02:13 PM
7d82adz's Avatar
the 83 was a car that originated from the northcarolina area, then went to massachusetts for the last 10 or so years, then i bought it in mass this summer.
atm the car is in a garage being worked on by someone, last i heard he cleaned the plugs, and put fresh fuel in it.. still backfiring in intake, hes thinking it could be the afm.
It was parked by the previous owner last year with whatever problem the car has, basically it just backfires like i said, and can only rev to about 2k max and barely move/drive in 1st gear.
the compression is decent, 20psi difference across the board. lowest being around 120 i think.. and before the car fell into a "sickness", the previous owner, woman driver said the car went along very well..
which in turn makes me very hopeful for a simple fix. because the rest of the car is near mint.
Old Aug 27, 2013 | 06:54 PM
Backfiring into the intake means gas is getting in there. Unless the injectors are leaking it's coming out of the intake valve. If it's coming out of the intake valve it's most likely the timing...
Old Aug 28, 2013 | 07:06 AM
ken99's Avatar
If the timing light indicates the engine timing is retarded, I'd start by checking the timing gear and chain. See:
https://www.zdriver.com/forum/240z-2...e-l28et-30099/
Old Aug 28, 2013 | 02:40 PM
7d82adz's Avatar
backfiring in the intake maybe a bit much to say about it.. idk, to be more specific on that symptom its more of a "popping noise" rather than any sort of loud bang noise..
the previous owner has stated that the car has gave her this problem before, got it fixed by someone, somehow,.. who knows, but then the same problem quickly came back within the same week. and then the car was parked since.
im really leaning towards it being electrical related, cuz the car ran good, fell into having issues, got temp fix, then issues, then parked.
comparing a faulty 83afm to a 77 afm.. would the car possibly run any better? or is it completely non compatible/bad for it?
also anyone know of a good route to go on as far as replacing the 83afm with a quality replacement?
thankyou
Old Aug 28, 2013 | 05:04 PM
Did you see this?
https://www.zdriver.com/forums/240z-...our-afm-15277/
Old Sep 5, 2013 | 03:06 PM
Did you meter out the harness as per the FSM instructions? (XenonS130)
Old Sep 6, 2013 | 05:03 PM
its gonna be afm or dizzy related. check the timing and the inside of the cap for poor connections. as well as maybe new plug wires as they may have become separated in the boot with everyone pulling them off and on. make sure the dizzy shaft has no play in it as well. follow the pinout test in the fsm and test and check your afm. im sure you find something.
Freshzx
Aug 2, 2014 09:30 AM
ComputerChip
Jun 13, 2013 04:26 AM
captken
Aug 24, 2009 10:14 PM
captken
Aug 19, 2009 02:56 PM
