'82 turbo starting issue
Old May 19, 2010 | 02:48 PM
gilmorej3's Avatar
Hoping someone can guide me on this starting issue for my '82 280zx turbo.
When I turn the key normally I will hear the fuel pump and then when it stops I can start the car. What is happening now is I turn the key and instead of hearing the fuel pump I hear a clicking noise in the ignition relay under the dash and the car won't start.
Relays, fuseable links and ignition switch are all new.
Thanks in advance.
Old May 19, 2010 | 02:54 PM
Welcome to ZDriver!
So the fuel pump DOESN'T turn on at all?
And the clicking noise from the ignition relay is under the dash where? Drivers side? Passenger side? By the glove box?
Have you recently touched the ecu or any other wires? Did this happen out of the blue or were you working on the car?
Old May 19, 2010 | 02:57 PM
gilmorej3's Avatar
Welcome to ZDriver!
Fuel pump does NOT turn on. The clicking relay is on the passenger side to the right side of the glove box. I changed it this morning just to see it that was the problem. No change.
The problem has been going on for some time (years off and on). We have been working on the car because of this issue.
Not sure about the ecu or other wires. (sorry)
Old May 19, 2010 | 03:01 PM
Did you change the GREEN relay on the right of the glovebox? That's the fuel pump relay, and takes some digging to get to. Sounds like that relay isn't working.
Have you also checked to make sure the fuel pump module above the ecu in the driver kick panel is securely grounded?
Old May 19, 2010 | 03:07 PM
gilmorej3's Avatar
I'll check the fuel pump module. That hasn't been done. The relay I changed wasn't green but there wasn't a green one under there. Two blue and a black. The one I changed had a green wire leading into it. I was going off a diagram in the book. :-|
Old May 19, 2010 | 03:08 PM
Yep... you need to change the green one that has a blue w/ red stripe wire.
Old May 19, 2010 | 03:13 PM
gilmorej3's Avatar
I just rechecked. That is the one I changed. Thanks.
Old May 19, 2010 | 05:25 PM
They I'd be checking the fuel pump, and fuel pump connections.
Defender405
May 28, 2015 08:48 PM
1979 280z
Jan 5, 2015 02:58 PM
Unorthodox
Oct 11, 2013 11:15 AM
OpenRange
Aug 26, 2009 12:54 PM
280z racer
Sep 25, 2007 11:29 AM
