280zx bogs, overheats, and sounds like a subaru(not in a good way)
Old Jul 24, 2010 | 11:37 PM
aojedam's Avatar
hello thanks for reading in on this i really appreciate it......so i have several problem with my stick 83 N/a Z
1st is..the car runs at almost 3/4 of the way on the temp gauge replaced everything but the radiator(but took it out several times and washed it out)
thermostat, wp, sensors, fan clutch, hoses. problem still persist. i even added a pusher fan too...
second. the car sounds like a subaru but not in a good way like if one of the cyls were not functioning. i messed with dist timing, helped advancing it but pinged like hell... stumped(hint of fuel odor sometimes comes up)
fuel pressure regulator?
any help is apreciated thanks...
Old Jul 25, 2010 | 03:54 AM
Possible, you could have a dead cylinder. And maybe a burnt valve? Just a stab. Did you check your oil? And see if it is milky? Are you losing coolant? Also are one or more of the cylinders not firing? Anyway, could be numerous things that could cause it. Supply us with more things. And maybe we can point you in the right direction. Good luck
Old Jul 25, 2010 | 08:23 AM
timing is retarded alot. chrck that and get back. if someone messed with the oil pump drive and didnt quite get it, it puts the dizzy out a wee bit.
Old Jul 25, 2010 | 10:09 AM
rogerz's Avatar
Grumpy & Helpful
depending on the stock gage system for an accurate temp reading is like trying to win the lottery. See if you can borrow one of those infrared guns and get an accurate reading. Radiator might be plugged. if you could find the fuel pressure, vacuum, compression readings and post them you could get better help. How do your plug wires look, dizzy cap and rotor. Use a timing light and see what your ignition is doing.
Old Jul 25, 2010 | 12:33 PM
aojedam's Avatar
infrared thermometer is the next thing will do.
but i also suspect a clogged radiator. i changed the head gasket before to add a n42, turns out the head had a crack, so i put the original back on. then this.
...as for the bogging it runs good, but when it gets warmer it happens, so i think the over heating and the bogging are somehow connected. is it possible that after many years gas has eaten out the internals of the pressure reg?
Old Jul 26, 2010 | 02:21 PM
audiofreak97's Avatar
Oh yeah?! Freak this!!!
Have you checked the CHTS? Bogging and missing could also be a sign of a bad head gasket, did you have the original head checked before you put it back on?
Old Jul 27, 2010 | 06:04 PM
aojedam's Avatar
how would i know if the chts is bad?
i disconnected it it slowly drops idle and almost to the point it wants to turn off
..Good> bad?
i had a proble with the felpro 8799pt
some of the coolant holes were closed off, so i used the older head gasket from felpro also...but the orig head is good. had it checked and resurfaced.
oh and by the way... would taking the heat shields off the manifolds cause a over heat problem?
Old Jul 28, 2010 | 02:20 AM
..Good> bad?
From what it sounds like. Your CHTS, is working properly. If you unplugged it, and the car wanted to die. It is good.
From my experience, taking the heat shields off the manifolds. Do not cause any problems. And you eliminate, having to fight with those things later on. Those are one of the first things to come off. When I work on my Z's. Makes it a lot easier to work on it, after you take them off. One of the best upgrades in my opinion. And also from my experience. Is get an exhaust header, and ditch that stock exhaust manifold. One of the bad things, they put on these cars.
Anyway, have you checked your oil for milkiness? And your timing should be 8 degrees before top dead center. Also, when you rev the engine. Do you get coolant shooting out the overflow? Also check your plugs, and see how they look. There are lots of things, you can check, and troubleshoot. Also see if you are losing coolant.
Old Jul 28, 2010 | 02:18 PM
aojedam's Avatar
i did check for symptoms of a head gasket...
coolant is clear...oil is...oil color...not milky ...tried checking timing, but the little metal piece is missing, i got one from the junk yard but somehow i dont remember how it went...
i ordered header wrap to see if it will help a little bit
thanks for the advise
Old Jul 28, 2010 | 04:59 PM
skib's Avatar
This facepalm's for you!
have you actually checked to see if theres a dead cyl yet?
Old Jul 29, 2010 | 03:55 PM
aojedam's Avatar
ok so i went to autozone and rented a compression tester, but didnt have some fittings...
but as soon as i test them ill post the results
Old Jul 31, 2010 | 05:21 AM
WanganDevilZ's Avatar
The Emblem Thief y0!
UPDATE UPDATE UPDATE!
What happened? Did you check yet? Don't be like me and let your Z sit for a year before finally getting your ***** in order to fix it!
I barely remember what it even sounds like anymore.
Old Aug 1, 2010 | 11:39 AM
aojedam's Avatar
im beginning to give up....i wrapped the headers put the heat shields back on. same friggin problems. compression was one sixty changed coil dist cap n rotor wires fuel filter only things left is tps n fuel pump n reg
Old Aug 1, 2010 | 11:40 AM
aojedam's Avatar
getting expensive....thinking bout sale...
Old Aug 1, 2010 | 05:58 PM
do a power balance test. as its running unplug one injector at a time. when one gets pulled off and the engine has no change in how its running itll give you the cylinder that is not running correctly. if they all make the engin run more poorly equally, then you have an engine control problem. try that and get back on here. we can help solve it easily if you keep at it and listen. dont spend any more coin until you narrow it down. good to hear about the comp check.. sounds good for stock to me.
Julya-zombie
Oct 15, 2019 09:34 AM
Kevdogg
Jun 23, 2014 09:53 AM
300zeex
Dec 23, 2011 06:36 PM
SloppyGoat
Jul 20, 2009 07:36 PM
iriegirli
Other Cars
Aug 27, 2005 05:18 PM
