2+2 Rear End Question
Old Sep 20, 2005 | 01:51 PM
CWHammer's Avatar
Under My Car... brb
I had to replace the rear brakes on my '83 2+2 over the weekend. While I had the car on stands I was remembering a prior post regarding lsd's and spinning one wheel to see which dir the other turned. Turns out that when I spin either wheel the other doesn't do anything. Is this an indication that the rear diff is toast?
Old Sep 20, 2005 | 01:54 PM
nope... means it's fine, since the stock 280zx diff is an OPEN DIFFERENTIAL. Usually the other tire spins the other way, but if there is any drag, then it won't spin at all.
Old Sep 20, 2005 | 01:56 PM
BTW... about the only way to "TOAST" a 280zx diff, is to have 250+ whp & be doin a ton of hard launches... and even then, you'll break the spider gears, AND YOU WILL KNOW YOU BROKE THEM.
Old Sep 20, 2005 | 09:30 PM
jfairladyz's Avatar
If you had a toasted diff then you wouldn't need to change your brakes You'd wanna make sure the towtrucks got good brakes though
Old Sep 20, 2005 | 09:34 PM
lww's Avatar
lww
Head Muckraker
I'm still running the original R200 diff in my Turbo and it's holding up fine.
You'll break a lot of other stuff before you start to give these trouble. Tranny, axels, u-joints, etc.
Then, you can go up to an R230 which is a beefier R&P than a Ford 9".
Old Sep 21, 2005 | 08:19 AM
oh really! Is the R230 just a bolt-in swap like everything else?
Old Sep 21, 2005 | 12:51 PM
R230 as in the 240sx diff? That pumpkin won't bolt up the same at all...
Old Sep 21, 2005 | 08:21 PM
jfairladyz's Avatar
If you need something that strong then it's probably worth the effort to make it fit That be a whole lotta Torque A 9" will take a whole bunch of abuse. Trust me, I know first hand
Old Sep 22, 2005 | 08:38 AM
The Z32 TT has the R230 LSD, right? 3.54 ratio
one_fast_300zx
Jan 29, 2009 12:48 PM
topdoggcarlos
Apr 6, 2005 08:10 AM
jersey300zx
Jan 12, 2005 07:10 PM
CrazyLotusTT
Jun 25, 2002 11:23 PM
