Ac Leaking Freon?
Old Sep 18, 2005 | 10:19 PM
Texaz's Avatar
Ac Leaking Freon?
I just got my new 83 280ZXT and charged the AC about a week ago. Now the AC still blows but the air is HOT! In Texas that is definitly not a good thing. Anyone have any ideas what this could be and how much it will cost me?
THANKS!
Old Sep 18, 2005 | 11:23 PM
did it work BEFORE charging it? Was R12 used? Does the a/c compressor engage when u turn on the a/c?
Old Sep 19, 2005 | 05:54 AM
Texaz's Avatar
The compressor does engage, R12 was used and no it didn't work before it was charged. Thoughts?
Old Sep 19, 2005 | 09:50 PM
jfairladyz's Avatar
If it's R12 are you so lucky as to have a stash so that you did it yourself? If so, and the system was in need of a charge, then there is a very good chance that the system is contaminated with moisture. Also, too much or too little refrigerant can cause a warm condition. If the compressor is coming on then it's gotta be internal. Check to make sure the condensor isn't restricted at all. The reciever should also be replaced if there is a chance that it was exposed to atmosphere (like someone venting it or a leak). Finally, the restrictor orifice may be restricted to the point where enough refrigerant isn't allowed to pass and is backing up the flow which will raise the pressure and prevent the system from cooling. But your best bet is to just take it in and have it serviced. Have em pull a vaccum on it and see if it's leaking. This will also get out any moisture. If it was leaking make sure they replace the reciever. R12 is expensive though.
Old Sep 20, 2005 | 03:31 AM
Just use the stuff called "freeze 12" It is a replacement for the original r-12. I put it into my Celica which had r-12 originally, and it worked fine, until my damn compressor froze up! And I didn't want to know, how much another one cost. So I will wait until next summer. And hopefully replace it.
Old Sep 20, 2005 | 12:08 PM
lww's Avatar
lww
Head Muckraker
http://autorefrigerants.com/co00033.htm
Old Sep 20, 2005 | 09:27 PM
jfairladyz's Avatar
Where the hell do you find all this stuff lww. You're a freakin' machine. Put a quarter in and a link pops out. It's great. Especially since we don't even have to put the quarter in . 12 cans of the stuff for $60, that's a hell of a lot cheaper than R12. Maybe I'll put my AC back on after all. Then again, maybe not.
Old Sep 20, 2005 | 09:36 PM
lww's Avatar
lww
Head Muckraker
You guys probably don't know this, but I actually DO run the internet.
I'm not being facetious here... I really do.
Old Sep 20, 2005 | 09:52 PM
jfairladyz's Avatar
And I thought you were just a regular guy who had a lot of cool cars and a Honda
Hey, where'd your sig go? That's really weird, I was just looking at it in another post about the diffs.
Old Sep 22, 2005 | 12:17 PM
Z*Tech's Avatar
I believe the heater core/ A/C plenum is vacuum controlled on that model. Check to see if the doors are opening and closing. If they aren't the hot air is from your heater core and will defeat the A/C
datsuns130
May 9, 2012 09:41 AM
81-280zxnt
Sep 25, 2009 09:48 AM
FaYeZ_90NA
Mar 17, 2005 10:28 AM
droc217
Feb 5, 2005 07:53 PM
ADukesIII
May 15, 2003 09:25 AM
