sway bars....
Old Oct 15, 2007 | 01:48 PM
sticky280zx's Avatar
sway bars....
can u tighten them too much (at the endlinks)?? and theyre a lil sqeeeeky so i think ima put some spray white grease...or should i take em loose from the endlinks and use black grease??
Old Oct 15, 2007 | 02:08 PM
I don't think it's the end links (or ONLY the end links) squeaking. The stock control arm bushings are known / prone to squeaking. White lithium grease helps a lil... but will wash away when wet. Real bushing grease will do the trick... but if you take off the bushings, you should just replace them anyway.
Old Oct 15, 2007 | 05:09 PM
if they squeak when you go over a speed bump (entire front end of the car goes up and down) then its likely the sway bar mounts on the body where the bar twists inside of it.
Anti-seize works perfect as urethane lube. Unbolt the bar and stick some of that junk in there.
Old Oct 15, 2007 | 06:22 PM
260zturbo's Avatar
Stupid Hurricanes...
i think sway bar end links are tq to 15lbs if i recall. but yea if ur gonna take them off go ahead and get some urethane bushings.
Old Oct 17, 2007 | 11:09 AM
yea well i got eibach 7/8rear and 1inch front aftermarket sway bars and msa endlinks with all poly bushings no use in getting sways and keeping the old rubber also another question about my springs/struts i have the eibach lowering springs and the tokico illumina 5ways all around and i have the backs installed and cant really tell a difference....will it lower the car like i want it to or do i need to do something else besides just put em in?
WanganDevilZ
Mar 6, 2010 02:30 AM
OldschoolZ
18
Mar 31, 2006 06:55 PM
91zxtt
Jan 7, 2005 02:10 PM
Drax240z
Jan 30, 2001 07:10 PM
