Please help with my hood!
Old Oct 12, 2007 | 11:21 PM
jimp280z's Avatar
This has had to have happened to someone else.. My hood cable broke and I don;t know how to get my hood open. Any tips?
Old Oct 12, 2007 | 11:35 PM
Welcome to ZDriver! Where on the cable did it break? Can you grab it w/ a pair of vice grips & pull?
Old Oct 13, 2007 | 02:05 AM
jimp280z's Avatar
whole cable
I cant grab the cable. it broke from under the hood. There has to be a way to open the hood without cutting it right??
Old Oct 13, 2007 | 02:21 AM
thxone's Avatar
I will look at mine tomorrow and see if I can troubleshoot the problem for a solution. It looks grim however.
Old Oct 13, 2007 | 08:04 AM
BC240Z's Avatar
From: Kelowna B.C. Canada,.The Beautiful Okanagan Valley!.,.Canada's "Cali"
This is not an easy task!
I broke the cable on my '72 240 4(?) yrs ago........
We had to slide under the car with a flashlight, looking behind the engine from the drivers side, past my header etc. we could just make out the small "tab" that you have to push. it is almost centered almost directly behind the valve cover.
The lever is of course in the middle of the latch plate... inside a box almost! its crazy, but it can be done. the lever, will pivot towards the drivers side. put your finger in the side of the latch "box". you will feel the lever..pull towards you.
Good luck!. this is a real A-hole to perform.... I left my hood open to the first safety latch for several years after I broke that sucker! (paranoia)
.. Uh one last thing. I feel the need to mention that I am a small guy. 5'5" an' about 110 pounds.. I can get my puny hands up there to the latch... a larger.. err "normal" sized human, may find it even more difficult... got a skinny G-friend?
Good luck ... Todd/BC240Z
Old Oct 13, 2007 | 10:27 AM
flightforlife07's Avatar
hey j when i back down next time let me know i got a spare cable i think or two i'll throw your way I should be back next weekend... give me a call
Old Oct 13, 2007 | 11:17 AM
nismo619's Avatar
good luck the hood cable broke right were i pull it from inside the car i used a pair of vise grip clamped down good and pulled hard i fixed my problem with a new oem cable. cost way to much !
Old Oct 14, 2007 | 05:18 PM
jimp280z's Avatar
Thank you for the help. I will give it a try from under the car but if that doesn't work, I'll have to cut the hood
Old Oct 14, 2007 | 05:25 PM
need a set of these, i have them just havent put them on.
Old Oct 14, 2007 | 11:50 PM
hey j if you end up having to cut it i got a spare hood i can throw your way just hit me up...
Old Oct 15, 2007 | 08:32 AM
BC240Z's Avatar
Unhappy
If you can get the car on stands. you WILL be able to get under there.. IF you have long-*** arms.. you WILL be able to trigger the release.. gosh man, dont chop it up!!!
I managed several times to open mine, when 'tard's would close my hood alla-way without asking! .. I finally rigged a choke cable to work, one day I will replace it with the proper piece/Cable.
Todd/BC240Z
Old Oct 15, 2007 | 08:39 AM
hellraZor's Avatar
here is a clip from the JTR v8 manual hope it helps
Install the hood latch and cable. The hood latch bracket (page 2-f f) is installed on the lower side
of the firewall bracket (page 2-1O). DO NOT SHUT THE HOOD UNTIL YOU ARE SURE THE
CABLE OPERATES THE RELEASE MECHANISM PROPERLYI Otherwise, the hood will not open
and there will be lots of swearing. If thls should happen, the front of tJle hood can be unbolted
from the front of tJle car to gain access to ttre latching mechanism with rrlrrimal body damage.
Old Oct 19, 2007 | 07:13 PM
jimp280z's Avatar
Thank you
I was able to get my hood open so I want to say thanks and now I can continue my work. - Exept I have a new problom
Old Oct 19, 2007 | 10:11 PM
duckyz's Avatar
Uh oh, not good....
ZXT83
Oct 18, 2009 05:24 PM
roneski
Feb 15, 2006 11:27 AM
rifleman502
Dec 4, 2004 08:31 PM
Ramen Sama
Apr 29, 2003 01:30 AM
Ramen Sama
Apr 15, 2003 10:57 PM
