Rear control arms stuck
Old Aug 25, 2012 | 05:11 PM
mikeatrpi's Avatar
This is strange. The "outer" bolts seem to be stuck to the inner bushing sleeve on both of my rear control arms. The "inner" bolts (towards the center of the car) came right out. To be clear, the nuts and washer came off - but I cannot remove the bolt to extract the control arm. I can rotate them with a breaker bar... the control arm swings up, and then falls slowly. But I cannot easily spin them nor push them out.
Does anyone have any tips for me? Thanks!!!
Old Aug 26, 2012 | 08:33 AM
I take it the control arms are hanging free? Did you try putting a jack under the arm to relieve pressure? Did you try tapping on the bolts with a hammer?
Old Aug 26, 2012 | 06:19 PM
mikeatrpi's Avatar
Yes the control arms are hanging free, tried jacking them, etc... but I can't fit a hammer in there except for gentle taps. I think I'm going to drop the subframe to get better access. I just need to do a little metal work on the rails so I have a place that I trust to be strong enough to support the weight. Usually I put the stands under the subframe.
Thanks for the suggestions!
Old Aug 27, 2012 | 06:59 AM
yup had that happen a million times. get a saws all and cut either side. then get new bolts and bushings. only way its gonna come out.
n-sane-1
Nov 24, 2012 07:14 PM
dreamz90tt
May 26, 2009 03:06 PM
coyotegary
Jan 20, 2008 12:53 PM
znasty1
FS: 300ZX (90-96)
Apr 7, 2005 09:52 AM
StealthZX
Mar 28, 2002 08:45 AM
