hood mod
hood mod
hey guys, ive seen this done on a couple mustangs, but i want to take it to the Z, the hood, it uses a spring to hold open when you open it up, real pain in the *** to replace at times, well i want to remove the springs and replace them with hydrolic struts like on the back hatch
anyone ever seen this done? if so what are the measurements and strut sizes i should use?
any help would be great, thanks
Zac
Zac
The Z31's have the hood struts, but the hood also opens from the front, not the rear like ours do. I personally haven't seen anyone do it, but you could probably use the same strut from a Z31 and weld a reciever to the hood and to each 1/4 panel or the radiator support.
The only problem that I see is that a 280ZX hood is much lighter than a Z31 hood. The struts could be too strong for the application. Also, fitting the struts where they won't interfere with the hood closing might be a real pain in the ***. If you do alot of work yourself, the struts might also interfere with accesibility to certain motor parts.
Just something to think about.
jimp280z
13
Oct 19, 2007 10:11 PM
