drive shaft problems !!!???
Old Feb 3, 2006 | 09:25 PM
nismo619's Avatar
im finding it very hard to get off the drive shaft whitch side do i take off first the one on the back of the auto tranny or the end towards the rear diff. ? is there and eazy way to unblot this ? please let me know ASAP the junk yard is coming monday morning !@!!!!!
Old Feb 3, 2006 | 09:31 PM
Loosen the nuts on the differential flange & it should drop right down.
Old Feb 3, 2006 | 10:11 PM
nismo619's Avatar
thanks, p.s. do i use the emergency brake to stop the wheels from spinning? i have the car in the air on 4 jack stands only i wish i had a LIFT !!!! =-(((
Old Feb 3, 2006 | 10:32 PM
yeah... use the ebrake, put it in gear, or you can put a screwdriver in between the flange & end of the tranny tunnel for leverrage.
Old Feb 4, 2006 | 01:01 PM
nismo619's Avatar
thanks nismo pick i was albe to get the rear drive shaft off but one of theb lots was pretty badly rusted so i used my trusty high speed fremel tool with my cut off wheel and cut it half way down and wall la !! it cam right off at first had a problem tring to get it to dislodge so i hit a a few time with my 20mm wrench =-) a few taps and wall la !! came down no problem now... i just need to unblot the auto tranny mounts and then unblot the engine mount and then i will need a cherry picker to pull her right out am i right ?
Old Feb 4, 2006 | 02:40 PM
Once you have the tranny out, and all the wires / connections unhooked from the engine: pull that sucker out! Yes... an engine puller "cherry picker" will work wonders.
Old Feb 4, 2006 | 07:22 PM
nismo619's Avatar
i think i hve the engine sold to a customer hear on zdriver.com he offered me 700 dollars plus shiping
86_VG30ET_Z31
Feb 24, 2013 09:25 AM
stromtho-26
Dec 31, 2010 03:40 PM
zordietrying
Nov 16, 2010 06:47 PM
terrymac
Jun 17, 2009 12:46 PM
gbelous
Jul 12, 2002 12:54 PM
