Starting Problems
Old Aug 2, 2002 | 01:55 PM
Re: Starting Problems
Well, when it does this, pull off the valve cover vent hose connection. It plugs in right in front of your throttle body. Spray in some starter fluid while keeping the throttle opened by pushing down the linkage with your other hand. Then, quickly get in the car and crank it. If you suddenly get some spurratic firing in a cylinder or two, then you know for sure that it is a fuel problem. (have the starting fluid readily available)
If nothing fires, then possibly it is related to the spark. You can replace your coil just to see if it is that. There is also a possibility that the starting fluid doesn't reach the engine in large enough amounts to fire. I haven't done this test myself yet, but that stuff burns very easily so the test should work.
OsidonZ31
Mar 10, 2014 12:47 PM
300zgearhead
Jul 21, 2010 04:04 PM
TeamRonin
Feb 18, 2010 01:22 AM
KasbeKZ
Jan 17, 2009 05:10 PM
Stubby
May 7, 2005 11:18 AM
