starting issue
Old Sep 22, 2007 | 08:18 PM
280z racer's Avatar
starting issue
Ok the car has spark, the fule pump was not terning on so I ran a B+ to it and it works, but the fule injecktor's are not geting a signal is it a relay or modular or what I have no clue.
Old Sep 22, 2007 | 08:52 PM
entropy31's Avatar
The Cake Is A Lie!
Originally Posted by 280z racer
Ok the car has spark. The fuel pump was not turning on, so I ran a B+ to it and it works. But the fuel injectors are not getting a signal. Is it a relay or module? I have no clue.
made it a tad easier to understand.
Old Sep 22, 2007 | 09:17 PM
280z racer's Avatar
Ok. I have spark and tried to start the motor and nothing. Then I found out the fuel pump was not on, so I ran a B+(power wire) to it and it turned on. So I tried to start it again and nothing then I used ether and still nothing, then I checked if the fuel injectors for power nothing, so what is it?
Old Sep 23, 2007 | 11:46 AM
What method did you use to verify no power to the injectors? Hopefully not just a regular light bulb or voltmeter...
Old Sep 23, 2007 | 12:07 PM
yeah, you need a fancy LED. lol
Old Sep 23, 2007 | 09:35 PM
280z racer's Avatar
I used a diod fuel injecktor tester. I thingk it mite be the fuel pump relay or the EFI relay.
Old Sep 23, 2007 | 10:47 PM
its not the FP relay it doesnt control anything but the FP. could be the efi relay but then your entire ecu wouldnt work. do you know if your ECU is even getting power/turning on?
Old Sep 24, 2007 | 02:44 AM
megs's Avatar
Grab yourself a mechanics stethoscope and put the needle on the injector while someone cranks. If they are getting power you will hear them open and close.
Megs
Old Sep 24, 2007 | 12:34 PM
280z racer's Avatar
there is wire by the battery that is frayd and looks like it should go to power, it has a weight plug below the fray. when I put it to power I hire a cliking on the driver side.
Old Sep 24, 2007 | 12:37 PM
280z racer's Avatar
is there even a fuel pump relay on a 77 280z?
Old Sep 24, 2007 | 02:10 PM
If it has an electric fuel pump... it has a fuel pump relay.
Old Sep 24, 2007 | 03:11 PM
280z racer's Avatar
I can not find info to where it is?
Old Sep 24, 2007 | 03:27 PM
Do you have the Haynes manual / FSM??? It should be clearly visible in there. If not... have you seen our documents thread that has the manual in it? https://www.zdriver.com/forums/showt...974#post194974
Old Sep 24, 2007 | 04:11 PM
go me!!!! also there is this site:
www.atlanticz.ca
Old Sep 24, 2007 | 04:12 PM
sorry here is a direct link. but the site seems to be temp down
http://www.atlanticz.ca/index.php?op...pper&Itemid=69
Old Sep 24, 2007 | 04:13 PM
280z racer's Avatar
I have the book but it dosen't tell **** for that.
Old Sep 25, 2007 | 09:47 AM
280z racer's Avatar
How do I test to see if the ECU is geting power?
Old Sep 25, 2007 | 10:01 AM
unplug it and use a volt meter across the prongs.
Old Sep 25, 2007 | 10:34 AM
280z racer's Avatar
Witch ones? And how does the EFI harness get it's power?
Old Sep 25, 2007 | 11:29 AM
Did you see this? There are tons of tests that are explained in the Haynes Manual, and in the 280z EFI Bible: http://www.atlanticz.ca/zclub/techtips/EFI&fuel.htm (bottom left of the page).
1979 280z
Jan 5, 2015 02:58 PM
Unorthodox
Oct 11, 2013 11:15 AM
GreenMachine
Jul 29, 2012 08:09 AM
Lesnocker
Feb 11, 2011 01:13 PM
OpenRange
Aug 26, 2009 12:54 PM
