starter problems
Old Apr 25, 2011 | 05:33 PM
pro260z's Avatar
starter problems
i have a 75 280z and when i hook the battery cables up the starter turns over automatically. not sure of problem can anyone help.
Old Apr 25, 2011 | 08:38 PM
Welcome to ZDriver!
Is the key set to START?
Old Apr 25, 2011 | 09:31 PM
BlueKitsune's Avatar
Intrawebz Wizard
Um did you put the + cable on the proper side of the starter?
Old Apr 26, 2011 | 10:42 AM
Ah... that would do it.
Old May 10, 2011 | 08:03 AM
pro260z's Avatar
thanks for the info i got it to work but the ignition isn't working i bought a new ignition switch and it didn't help. when i turn the key over nuthing happens any answers.
Old May 10, 2011 | 08:50 AM
Intrawebz Wizard
Have you checked all your fuses and fuseable links? Also making sure the signal wire to the starter is connected?
Old May 12, 2011 | 01:17 PM
pro260z's Avatar
fuses are good but i am still having a problem. i can turn the car over with a push button and i am getting power up untill i get to the ignition. evrything turns on with a push button but the ignition wont work any ideas?
Old May 13, 2011 | 03:55 PM
theramz's Avatar
I have a present for you...
When you turn it over that way you are by-passing the ecu and ignition which are turned on with the key. There are two wires coming from the battery to the ecu. One + and one -. When you turn the key on you should hear a click from under the dash. If you hooked the battery up wrong then you may have fried something. Buy an inexpensive muti tester, download the FSM from xenons30, (donate $5) and start checking everything. If you get stuck post it.
El_Colombiano
Jan 18, 2013 03:36 PM
Monkies
Nov 20, 2010 09:30 AM
81s280zx
Jul 11, 2005 08:02 PM
dapper189
May 29, 2005 03:16 AM
AlongCamePeter
Sep 12, 2004 06:20 PM
