Shifter won't select a gear
Old Feb 23, 2016 | 07:12 AM
Fast240Z's Avatar
Long time no chat guys! I took the Z out for a drive a while ago and got a bit too aggressive and broke the Z's tranny somehow. I was rowing through the gears quick, missed a shift and slammed it into 2nd, and all the sudden the shifter went mushy and it wouldn't go into any other gear or neutral. I was able to shake it around and finally pop it into a different gear and get home.
The shifter now goes into 3rd and reverse, but this is with much persuasion.
This is on my 72 240z, 4 spd F4W71-B trans.
Any ideas?
Old Feb 23, 2016 | 12:13 PM
So even with the engine off it won't go into gear?
Old Feb 23, 2016 | 04:03 PM
Fast240Z's Avatar
Correct, the shifter just feels sloppy and I can't feel any of the shift gates.
I also noticed that the freeze plug on the back of the trans where the shifter is inserted is missing. I suspect it popped out and may have caused the problem. Any idea where to get a replacement?
Old Feb 24, 2016 | 09:51 AM
Steve260Z74's Avatar
Drain the oil from the transmission and look for debris on the drain plug. If you tore it up, you'll probably see something stuck to the drain plug.
noobsauce
Jun 25, 2009 09:09 PM
yves280zx
May 14, 2007 07:05 AM
FubarI33t
Oct 15, 2006 06:42 PM
WildmaN
Apr 9, 2006 11:41 AM
KENZ
Aug 18, 2005 11:13 PM
