r200 swap on 78 Z
Old Jul 5, 2012 | 09:17 AM
jimbolo619's Avatar
r200 swap on 78 Z
So I came across a 87' 300zx and I'm wanting that open r200 diferential. I've done some research for this swap and kow it work but I'm curious bout a few things. Will my 78' Z axles fit right in the open r200 differential or will I have to buy the axles and all the brake assembly off the 300zx??? Thanks guys. I'm new to differentials and all...
Old Jul 5, 2012 | 09:32 AM
So you have an R180 or R200 right now?
If you have an R180, then Google search "R180 R200 swap" and you'll find the how to. If you already have an R200, it's a straight swap.
Old Jul 5, 2012 | 10:49 AM
77280ZX's Avatar
i thought the 78z had the r200 in it stock?
Old Jul 5, 2012 | 12:47 PM
ThaPimpShrimp's Avatar
This is what I found..
280z
77-78 MT = 3.545 (R200)
77-78 AT = 3.545 (R180)
300zx
84-87 NA = 3.7 (R200)
Old Jul 5, 2012 | 01:38 PM
Is there something wrong w/ your stock R200? Seems like a lot of work for nothing.
Old Jul 8, 2012 | 01:14 PM
theramz's Avatar
I have a present for you...
A great combo is '82 '83 2+2. Has close ratio 5 speed and 3.9 open diff. The 77_78 was R200 only in the 5 speed. The early 5 speeds were weak.
Old Apr 15, 2013 | 09:33 PM
jimbolo619's Avatar
Sorry for the SUPER late reply fellas. I just want the lsd upgrade sorry and yeah the differential is an R200.
Or the 3.7 gear ratio differential
Old Apr 15, 2013 | 10:01 PM
BlueKitsune's Avatar
Intrawebz Wizard
Its literally bolt in with your stock 280Z parts if your 280 already had an R-200 in it.
Its the same diff. just with different gears and Limited slip.
Old Apr 16, 2013 | 08:32 PM
jimbolo619's Avatar
Kool. So no switching axles or any major parts like that? Thanks BlueKitSune
Old Apr 16, 2013 | 08:50 PM
Just an FYI: you can't use the Z31T LSD finned cover on the S30's because of the mustache diff mount. So you have to swap over the stock smooth cover.
Old Apr 16, 2013 | 09:07 PM
Intrawebz Wizard
No prob! And yeah, what Nismo said
Old Apr 16, 2013 | 09:59 PM
PredatorZ's Avatar
Very cool
I could probably do something similar to my 280ZX
Old Apr 17, 2013 | 08:29 PM
jimbolo619's Avatar
Which model Z has the stock smooth cover?
Old Apr 17, 2013 | 08:33 PM
All long nose R200's that aren't Z31T LSD's.
Old Apr 18, 2013 | 07:07 PM
jimbolo619's Avatar
AHHHH! Thanks anyways NismoPick.
garretthes
Apr 21, 2012 09:02 PM
snwbrderphat540
Aug 22, 2007 12:04 AM
fast eddie
Oct 8, 2005 08:00 AM
gator bait
Dec 17, 2004 11:59 PM
jrqf
Jul 4, 2002 12:06 AM
