leaking water pump
Old Mar 25, 2007 | 10:46 AM
skittle's Avatar
Taste My Rainbow
leaking water pump
I think my water pump is leaking so when i pull it off can i use red rtv as a sealent or should i get a new factory gasket?
Old Mar 25, 2007 | 11:13 AM
i would get a real gasket.
Old Mar 25, 2007 | 11:54 AM
chinesekid's Avatar
gasket for sure
Old Mar 25, 2007 | 12:47 PM
3rd on that... the gasket is about $2 from AutoZone or free with a new water pump.
Old Mar 25, 2007 | 03:22 PM
well, you should all check my other thread, i wish a leaking water pump was the worst of my leaks....
Old Mar 26, 2007 | 08:13 AM
BoulderZ's Avatar
You sure it's the gasket, and not the spindle/bearing going bad? Not to cheer for the worst case or anything, I've just seen a number of the stock pumps go bad that way and was just wondering.
good luck,
Dave
Old Mar 26, 2007 | 12:29 PM
duowing's Avatar
NisTuner
Water pumps generally aren't even that expensive that if you have it off you might be better off just replacing it.
Old Mar 27, 2007 | 07:45 AM
skittle's Avatar
Taste My Rainbow
i pulled it off and the blades inside it looked great. I sanded down the original gasket pieces and rtv'd them. It no longer leaks and works like a dream.
sparkycon
Dec 6, 2011 07:22 AM
Fast240Z
Nov 26, 2010 10:58 PM
spoofyman
Aug 21, 2009 03:15 PM
preprodigy
Feb 11, 2008 12:46 PM
JAMESZ
Apr 15, 2004 08:24 PM
