Just bought a 1976 280Z. Got Questions
Old Feb 28, 2013 | 06:25 PM
Vedivan's Avatar
My is name Vincent I just got this car. I have some questions. The car hasn't been run in a long time, I fired it up on ether just to make sure it starts I'm thinking that I should drop the fuel tank clean it and flush the fuel system. I'm also thinking I should replace the injectors and do a full tune up. Is there a published tutorial for flushing the fuel system? What else should I be thinking about, and what is the best part source? Thanks!
Old Mar 3, 2013 | 06:33 AM
Vedivan's Avatar
I need help!
Old Mar 3, 2013 | 07:33 AM
rogerz's Avatar
Grumpy & Helpful
telling what car you are asking about would get you better answers. All Z's are not the same
Old Mar 3, 2013 | 05:26 PM
Vedivan's Avatar
Trying to remove gas tank
I'm trying to remove the gas tank on a 76 280z. Is there a trick to getting to the lines located on top of the tank? I've got everything removed nd the tank is hanging, but I can't get to those two lines to remove them. Thanks
Old Mar 4, 2013 | 06:26 AM
Click: XenonS30 - Free FSM Downloads
Old Mar 4, 2013 | 01:34 PM
Vedivan's Avatar
1976 280z
I have a 1976 280z
Old Mar 4, 2013 | 03:27 PM
Merged threads.
Old Mar 18, 2013 | 05:39 PM
Vedivan's Avatar
Fuel Pump, pumps, Wont stay running
1976 280Z
I removed my tank and had it cleaned. Before reinstalling it, I ran a line into a clean can of gas, and to the fuel pump. The pump is pumping, And the car fires on ether, but will not stay running. How can I test to see if the fuel is getting to the fuel injectors?
Thanks
Old Mar 18, 2013 | 06:09 PM
Thanks
Pull the fuel line after the fuel filter and look.
Old Mar 19, 2013 | 09:06 PM
Steve260Z74's Avatar
Have you verified fuel pressure? Have you verified the injectors are firing? Have you downloaded the FSM and Fuel Injection Bible from XenonS30
Old Mar 30, 2013 | 07:02 PM
Vedivan's Avatar
76 280z crank, no start
Replaced injectors, and removed tank and had it cleaned. After injectors replaced, I started the car using a coffee can full of gas, instead of the fuel tank. I then installed the tank, and also installed a fuel filter between the tank and the fuel pump. Now it won't start. I disconnected the fuel line at the rail, and it is getting fuel to the injector rail. I pulled 3 plugs and all three get spark. I've tried starting fluid, it won't start. I know all I'm supposed to need is fuel spark, and air. I believe I've got all three. Any suggestions?
Old Mar 31, 2013 | 04:45 AM
Vedivan's Avatar
Old Apr 1, 2013 | 09:15 AM
Merged threads... again.
Please stop making new threads & posts for the same issue.
I assume you mean you dropped the fuel pump pick up hose into the can?
Check the fuel pressure.
Sounds to me like you either have a dying fuel pump, fuel pressure regulator, or have the fuel tank in & out lines backwards.
ki5ngau
Apr 21, 2008 11:07 PM
mowermechanic
34
Mar 26, 2008 03:50 PM
VandiL
Feb 17, 2006 10:18 AM
Beanutoo
Dec 7, 2004 11:02 PM
Quickshift
Apr 13, 2004 09:13 AM
