help please
or fuel hose. last time i checked, its not a special hose thats going under any special conditions. and ALL the hoses on the old S30's (that were carb'd) had this shitty braided hose used. its complete crap hose also. i would replace all of it.
Go buy fuel hose from AdvanceAutoParts or autozone and quit over analyzing this crap. It is a hose. Period. if you aren't sure, don't use vacume line. just replace it all with Fuel line. beleive me, it can handle contact with gasoline fumes. its kinda what its designed for. and fuel line is one of those dirt *** cheap parts. Theres nothing special about it. It is a hose. it transports your fuel from point A. (fuel tank) to point B. (combustion chamber). Go buy some. i'd send you some of mine, but the shipping would cost more than the hose does. (hint hint)
(you'll have to forgive my dick-ism, but this is getting a little redundant. You sound alot like i did when i first got here. You sound like you is scared of your own car. buddy, they aren't that complicated. espcially not the old ones. )
cause i was going to keep it off till after i adjust my carbs. how bad could the carbs being tightened all the way be on the car's performance?
ok and how do i sync my carbs?
With a carb synchrometer. Here... let me type "SYNC" into the ZDriver search for you.
https://www.zdriver.com/forums/showt...highlight=sync
You can get a carb sync for a good price. MSA sells two. Pretty simple... you adjust each carb to the same flow.
http://www.thezstore.com/page/TZS/PROD/TE/60-9965 ($30)
or
http://www.thezstore.com/page/TZS/PROD/TE/60-9976 ($40)
or
ok but till i find one what do i move on the car to sync it? is it a lever or screw or what?
Can you not go to your local parts store and buy a friggin Haynes manual?
Here's a scan of that page:
