Help! My Z wont run
Old Jun 9, 2003 | 12:59 PM
icice9's Avatar
Super Siver & Black Stud
you probalby have a crack in your AFM boot.. that might have happend when you took out your tranny and your engine moved a lil but enough to tear a hole in your AFM boot. and if you have any vacuume leak in the boot it can cause your engine to run like that and hesatate. id check all your vacuume lines too.. did you replace your fuel filter yet.. if not you might want to do that too...
Old Jun 9, 2003 | 08:22 PM
lifegrddude's Avatar
Externally Wastegated
If it's not vacuum related, if the car sat for so long, it could have gummed up the fuel lines and injectors. Replace the fuel filter if you haven't already. Check the TPS connectors for corrosion, if they are corroded they can give a bad signal to the ECU. Make sure no moisture in on the contacts and same with the distributor cap and rotor.
John 82ZXT
little_leon60
Oct 6, 2011 11:04 AM
81 Black L28E
Oct 14, 2005 12:05 AM
RPS13_GZ32
Aug 16, 2005 12:24 AM
crazytvrguy280
Apr 28, 2005 09:36 PM
tyyr
Apr 6, 2005 07:39 PM
