wont run
Old Mar 12, 2005 | 07:10 PM
crazytvrguy280's Avatar
wont run
ok well this is not for me it is for my sitter in law dad and his 300zx will not stay runing for more thne 5min and then it will not start untill it is cold and i dont know i work on 280z not 300z
Old Mar 16, 2005 | 02:01 PM
FoxZ31's Avatar
does it run for a little bit then start stumbling really bad and seem like it's gonna die if you don't give it gas? if i so i had that same problem, i replaces the fuel filter and it solved it.
Old Mar 23, 2005 | 07:24 PM
he has repalce the fuel and all of the sentsor on the car
Old Mar 24, 2005 | 06:06 PM
JAMESZ's Avatar
Did he check the MAF? He has replaced all the sensors?
Old Apr 18, 2005 | 12:03 AM
s13z31killer's Avatar
The maf will only affect the car above ~2500 rpms
Old Apr 18, 2005 | 05:50 PM
JAMESZ's Avatar
It can and will affect idle.
Old Apr 20, 2005 | 01:37 PM
300zx nw's Avatar
you might have a blown head gasket. this will take time to fix but it the car get to hoot it will shut off, and wont start back up till it is really cool again or untill you fill it up with coolent. i had this problem.
Old Apr 27, 2005 | 09:26 PM
zcar300zx's Avatar
well wait hold on dont say its the head gasket without giving him some troubleshooting info...either you or a shop needs to do a leak test on the car...what you need to do is get a cylinder on the compression stroke, to do this take out a spark plug and plug the hole with a paper towel ( not in the damn engine just a lil in the hole) then crank the car by just barely gettin it to turn the starter...really dont just crank the car...just lil by lil...then on the compression stroke the paper towel will blow out...at this point insert a air blowing fitting to the spark plug hole and blow air into the cylinder.... k heres the info from the results of this test.... air bubbles coming from the radiators coolant = blown head gasket, air coming into the exhaust= bent or unseating exhaust valve, air coming through the intake and you have a bent or unseating intake valve....if you do get one of these results then do it again as to be sure you didnt crank it too far into the exhaust stroke...if you dont feel comfortable doing this then take it to the mechanic...im not gunna take responsiblity for someone screwin something up while doing this test...lol k good luck zya
Old Apr 28, 2005 | 07:50 PM
z31 chick's Avatar
my 300zx did that ****. if you pop the clutch before it dies, does it run a little longer? i'd say fuel injection?
Old Apr 28, 2005 | 09:36 PM
zcar300zx's Avatar
ummmm fuel injection....what do you mean?????everything under the hood is fuel injection...specify some more
little_leon60
Oct 6, 2011 11:04 AM
ZXT83
Jul 21, 2009 01:15 AM
81 Black L28E
Oct 14, 2005 12:05 AM
RPS13_GZ32
Aug 16, 2005 12:24 AM
tyyr
Apr 6, 2005 07:39 PM
