headers or manifold what is better?
Guest
Posts: n/a
i am going to have my machanic remove my stock 73 manifold with the smog pipe thing on it and replace it with a new jet coat header from msa, or a used stock manifold from a non-smog 240. i'm having him do it because the old manifold is leaking and one stud is broke off. my problem is i can't decide on what is better the headers or the manifold!!! can you please tell me the pros and cons of both. the things i want out of it is performance, longevity out of my motor, longest life, efficency. i dont want somthing that will warp or kill the engine over time.
i also was thinking of getting msa twice pipes, but im not sure of them either. what do you recommend?
thank you
thank you
Guest
Posts: n/a
headers dont do anything
except make lots of noise. the stock exhaust manifold was designed so well the adding headers wouldnt give any extra performance. its actually a waste of time and a waste of money. now twice pipes DO give you a performance gain, but headers wont. spend your money on a good exhaust system from the bottom of the exhaust manifold back. also grab yourself a cat to match the size of the pipe you are going to use. get a large diameter pipe. the larger the pipe, the deeper the sound. i had 2 1/4 put on and it sounded like a bumble bee. i didnt like it, so i had 2 1/2 put on. kinda sounds like a growling beast now. I recommend:
*stock exhaust manifold
*bolted flange 2 1/2 pipe from manifold to 2 1/2 inch catalytic converter
*bolted flange on both side of the cat to ease removal
*2 1/2 inch pipe from rear of cat to muffler
*3 inch inlet/outlet muffler
I promise you if you go with this setup you will be happy. i have TONS of experience with exhaust. I have changed mine over 8 times and have spent over $1000 on it. I did it all in finding the best setup , so trust me lol. Good luck dude
SoCalZ Prez
http://www.socalz.org
SoCalZ Prez
noelawinslow
May 21, 2013 01:17 AM
