Gearshift Problems?
Guest
Posts: n/a
Gearshift Problems?
A car I am looking a buying had problems with the gearbox, and i was wondering what was wrong and how exspensive it would be to fix. The shifting was really sloppy, and it was you had to get the technique right to get it in the right gear, i.e if you were going for third, you might put it in fifth without knowing. The guy said he thought all 240z gearboxes were like that, but i don't know. Does anyone know what the problem is, and how it can be fixed at what price? Thanks.
Guest
Posts: n/a
Re: Gearshift Problems?
Does the gearbox have a flange mount to the tailshaft or a slip-in spline?
The flange mount is what is known as the 'A' series gearbox (FS5C71A), used in the Fairlady Roadsters & 1970 240Z's. They use the Porsche Synchros (good) & the 'monkey-motion' linkage (bad) (the same as the 1600/180B) which can be can be as sloppy as.
The spline output models are the 'B' series (FS5C71B) and they have the shift the same as the 260Z/280ZX/Bluebird/200B/R30 etc. They use the Borg- Warner Syncros (not as good). But have a much better shift linkage assembly.
The 'C' series is what you see attached to the RB & SR engines etc.
There are variants of these units in gearing (close ratio, Option-1/2/3 etc) but the basic series-unit is the same.
Also what is the chassis number of the car? (located above the clutch master cylinder)
Guest
Posts: n/a
Alan the 71's did come with 5 speeds in the US. Must have been converted. The center console has to be cut to make room for it to shift properly. You will have to get the number off the transmission to figure out what it is. The Internet Z club has the number.
DonP
DonP
Guest
Posts: n/a
gav... they came as an option not as stock.. but i am pretty sure more than 70% that came as manual are 5speeds... dealers gave the option as a package or something... if memory is correct...
<font color=blue>76 260z</font color=blue>
The NiteRider
The NiteRider
Guest
Posts: n/a
I'm on my second gearbox now in my '78 260Z 2+2 and its still not perfect ... why not get him to nock a bit off the price and get one imported from japan that will be a lot newer ??
Jake Van Brisbane,Australia
'72 240Z (project)
'78 260Z 2+2 (daily drvr)
'72 240Z (project)
Guest
Posts: n/a
All 240Z's in Australia came with a 5 speed gearbox or an auto, no 4 speeds. It sounds like a flange type box. It is easy enough to get a later box out of a 260Z, 240K, or Skyline and convert. The later type box is stronger and parts are easier to get. Contact Zxtras in Melbourne, they will be able to help you. Phone no. is 03 93251100
hope this helps
Allan
hope this helps
Allan
