Electric or belt
Old Sep 8, 2003 | 08:52 AM
The middle of the gauge is the area you want to be in. Different thermostats will keep the temp at different degrees. One may be a 180 and the other 195 F.
If your radiator is good enough to keep the engine cool, then the thermostat will be able to hold the temperature at that level even under harsh driving or very hot weather. If the temp goes over that level, then either your thermostat is going bad, or you need a better radiator/fan setup.
In a hot environment, it might be best to run the 180 deg to keep the engine on the lower side. In a cold area, the hotter thermostat will help keep the engine warm and give you more heat inside for your heater!
Niku-Sama
Sep 28, 2008 12:32 PM
skupy
Nov 14, 2005 01:42 PM
antisub
May 15, 2005 02:57 PM
Metal_Mad_Dog
Apr 1, 2005 04:06 PM
Las VegaZ
Aug 31, 2004 04:00 AM
