78 280Z Shutting down
Old Oct 22, 2011 | 12:14 AM
viasloth's Avatar
Im posting this in 2 different spots cause im unsure where it should be. but i have 78 280z 2+2 i got from a good friend that no longer has time to work on it and his wife made him get rid of it. i was told it starts fine and all, but once its running it heats up and shuts down. i dunno if it overheats and shutsdown or if it happens when it gets warm, either way i need some help, and wanna know if this is an easy fix or not and what the problem might be thanks
Old Oct 22, 2011 | 09:21 AM
Welcome to ZDriver!
Kinda hard to fix a problem, when we don't really know what the real problem is. It could be a lot of different things.
Start with checking spark & fuel pressure when the problem happens.
Old Oct 22, 2011 | 11:22 PM
viasloth's Avatar
yeah I hear ya on that, i just havent been able to go pick it up yet so im not really sure just yet and since ive never had a Z and dont really know anything about them. but im gonna try and pick up this weekend and maybe i can give a little more info on whats happening. thanks for the reply though
Old Oct 23, 2011 | 08:36 AM
viasloth's Avatar
ok some new information. it shuts down once it reaches operating temp. i hope thats helps a little more. any help would be great thanks!
Old Oct 24, 2011 | 09:53 AM
theramz's Avatar
I have a present for you...
It could be as simple as a clogged fuel filter (2) or a bad fuel pump. There is an additional injector on the intake manifold (cold start valve) that turns on when it is cold and off when it is warmed up. It may be enough fuel but it turns off when warm so there isn't enough fuel pressure to keep it running. Time for you to download the Z bible (fsm)
Old Oct 24, 2011 | 12:07 PM
JSM's Avatar
JSM
That is true. I've seen a Z run only on the cold start valve. You go to give it gas and just falls on it's face. This one had other issues so it never shut off, but the main injectors were not firing.
Old Oct 24, 2011 | 03:24 PM
viasloth's Avatar
awesome i will check on that and thank you.
jalexquijano
Oct 21, 2014 08:41 AM
yeahididthat
Sep 19, 2012 11:44 AM
Rotor Head
Mar 12, 2007 06:09 PM
amazin
Feb 23, 2002 06:51 PM
