Car shutting off
Old Sep 8, 2012 | 07:48 AM
yeahididthat's Avatar
Exclamation Car shutting off
every time I turn, (so far only to the right) i get a burning smell and my car shuts off
engine stops working. brakes i have to pump to tome to a stop
whats wrong, last week i took out my dash to figure out why my marker, tail lights and dash lights wouldnt come on
found out the previous owner spliced into my wring harness to hook up a crappy radio.....
Old Sep 8, 2012 | 07:49 AM
also none of the above mentioned lights dont work
Old Sep 8, 2012 | 08:24 AM
rogerz's Avatar
Grumpy & Helpful
marker and tail lights can be the connector from the stalk switch wiring to the body wiring. I found a burnt wire there. probably affects dash also. get the schematic out of the fsm free download at xenon s130. take it to kinkos and have them blow up the relevant pages to 11x17. makes it a lot easier to read. get out your vom and start tracing wires. is your battery hold down secure sounds like maybe battery shifts when you turn right.
Old Sep 8, 2012 | 08:36 AM
stalk switch?
whats that
Old Sep 8, 2012 | 11:21 AM
rogerz's Avatar
Grumpy & Helpful
the thing that sticks out of the steering column for lights and turn signals. got switches inside and the wires go a connector that hooks up to the body wiring harness have to pull the steering wheel. I seem to recall
Old Sep 8, 2012 | 09:56 PM
Is your battery shorting out on the hood (not tied down?)
Old Sep 10, 2012 | 12:45 PM
no its not tied down
i cant open my hood
Old Sep 10, 2012 | 12:49 PM
That's likely the problem.
i cant open my hood
What? So... how do you add / check oil? Or do any other "under the hood" maintenance?
Old Sep 10, 2012 | 04:44 PM
Well I guess you know what you need to fix first....
Old Sep 10, 2012 | 09:16 PM
A battery flopping around in a locked down engine bay... I smell disaster...
Old Sep 15, 2012 | 08:16 PM
I know my hood wont open
If someone would answer my 1st question it would be better
Old Sep 15, 2012 | 08:53 PM
ThaPimpShrimp's Avatar
How are you supposed to do anything about it if you can't even open your hood. Figure that out and maybe you can fix your car...
Old Sep 16, 2012 | 07:22 AM
Ummm yeah...
no its not tied down [the battery]
So... OPEN YOUR HOOD.
Old Sep 16, 2012 | 08:57 PM
Hood fixed now
Old Sep 16, 2012 | 10:04 PM
Hood fixed now
UH. And..?
Old Sep 17, 2012 | 09:58 AM
Progress!
Old Sep 17, 2012 | 11:22 AM
now the battery is tied town
now im wondering if i replace my dash wiring harness if the cables would run to the marker lights? and tail lights and side turn signals?
Old Sep 17, 2012 | 11:26 AM
The dash harness is for the gauges, displays, and radio. The exterior lights are controlled by the combo gauge, which is not part of the dash wiring, it's part of the body wiring.
Click: XenonS130 - S130 Reference
Old Sep 17, 2012 | 11:29 AM
where could i find body wiring?
does body wiring cover the tail lights?
Old Sep 17, 2012 | 11:36 AM
75 Datsun 280Z interior body wire harness | eBay
this is body wiring from a 280z
I own a 280zx, would this be compatible?
Old Sep 17, 2012 | 11:39 AM
Nope.
Do your lights no longer work?
Old Sep 17, 2012 | 12:58 PM
Yes my marker lights, tail and the small side turn signals do not work, when i twist the stalk switch to the 2nd position my headlights turn on.
Old Sep 17, 2012 | 01:05 PM
Maybe it's the switch...
Before replacing everything "*****-nilly", try tracing the power (or lack of power) with a multi-meter.
Old Sep 19, 2012 | 09:32 AM
Cool
I dont have a multi meter
but im replacing all the wiring underneath, i feel it's unsafe with my current wires being exposed
Old Sep 19, 2012 | 09:40 AM
You can buy a multi-meter for ~$10 at Harbor Freight / Radio Shack / Your local electronics store. Works much better than guessing.
What wires are exposed? Did they melt? Pics? Why is it like pulling teeth to get info out of you?
