280Z Project Thread
Old Nov 11, 2009 | 08:46 PM
BlueKitsune's Avatar
Intrawebz Wizard
280Z Project Thread
Well Heres another build thread of mine. Probably mostly gonna be photos.
Nismo if you want you can combine the other threads into one big glob if you want but please leave this one out lol
I'm going to rip out all the EFI stuff and Install double SU carbs and also rip out the auto trans for a nice 5 speed. After that I'm going to change the rear differential to a R200 with 3.9 gear set. I'll also be doing a ton of body work, finding and killing all the rust I can find And turning it into a 1970 240Z clone (sept for the hatch anyways) Meaning I need to find the hood, grill, lights, bumpers, ect. I also want to get a nice air dam, ZG Fender flares, pannasport wide wheels and bullet fender mount mirrors. Then I'll re-badge it as a 240! Oh ya, With midnight blue paint!
Heres where I started at
And where Im at now
Aaaand What i ripped out so far lol
And the burnt out gasket. Im shocked it was that bad
Old Nov 11, 2009 | 10:10 PM
Intrawebz Wizard
Ok Im confused... I removed the EFI relay and I know the big one and my custom one is for the fuel pump. What are the other 2 for???
NEVERMIND! I figured it out. One is for the deleted AC system and the other is the inhibitor realy. I'm just gonna deleted both then make a new relay bracket.
Old Nov 12, 2009 | 12:52 AM
Intrawebz Wizard
Uh probably a dumb question but, one of the line on the charcoal canister broke off on me and now Im wondering if I can even use a charcoal canister with a set of SUs. Or do I run the vent line right into a port on the carbs and leave the thing out of the car?
Old Nov 14, 2009 | 09:38 AM
Intrawebz Wizard
Well I was trying to cut off the exhaust system and I broke nearly every blade I had and I lost my temper a little and punched a panel on the Z, turns out I found another entire panel covered in like 1/2" of bondo. Im starting to get worried....
Old Nov 14, 2009 | 09:24 PM
Intrawebz Wizard
My junk post thread!
Wow I found even MORE bondo and rust... Im starting to worry that this Z may be a goner..
Old Nov 14, 2009 | 09:55 PM
SpeciallySpiked's Avatar
I'm a Registered User!
Ah it must be nice to have a garage to do all of that in... But good luck!
Old Nov 14, 2009 | 10:21 PM
Intrawebz Wizard
Its nice and annoying at the same time actually lol And thanks. Im gonna need it @.@
Old Nov 15, 2009 | 03:04 PM
< cough ... buy my 280zt ... cough >
Old Nov 15, 2009 | 03:11 PM
Intrawebz Wizard
I would in a heart beat Nismo. but I dont have $3K nor will a bank give me a loan right now I'm pretty sure. Unless you would take payments? lol Wait lemme guess! No. Right? Actually PM me. I wanna see if we can work something out.
Old Nov 15, 2009 | 10:23 PM
skittle's Avatar
Taste My Rainbow
If you are in Utah then no to the canister. Looks like you have the same rust spot on the cowl that i do, surface only of course. If you are looking for a good rust free body then check down here in vegas. I'll keep an eye out for you as well. If you have any questions about the carb swap just ask I swapped back and forth on my 76.
Old Nov 15, 2009 | 10:41 PM
Intrawebz Wizard
ya the cowl is actually rusted through... ironically im going to vegas this coming weekend! to bad i cant play any lottos!
Actually as for the carbs its pretty straight looking. I only cusios about the return on the carb lines an the fi lines... the carb return line is like 1/2 the size of the EFI return line
Old Nov 16, 2009 | 09:56 AM
skittle's Avatar
Taste My Rainbow
Yup very easy to do the swap over. A whole bunch of us are dyno'ing our cars this saterday if your free you can come watch.
Old Nov 16, 2009 | 10:11 AM
Intrawebz Wizard
Ah neato. Not sure if I'll be in Vegas or still on the plane on Saturday.
Right now them I'm powder blasting the intake and exhaust manifold to get them to a nice shine. Then I'll install the carb and replace the electric fuel pump for a low pressure carb pump.
Old Nov 16, 2009 | 10:45 AM
skittle's Avatar
Taste My Rainbow
Thats what I had was a low pressure holly put out about 5 psi and worked great with the carbs. I sold my carbs but I still have 2 whole intake assemblies.
Old Nov 16, 2009 | 11:00 AM
Intrawebz Wizard
Well this one I have is a universal carter pump that the old owner put on then he couldn't figure out why the car wouldn't run! Hmm I wonder why... lol
Old Nov 20, 2009 | 01:04 AM
Intrawebz Wizard
Ok thats it. I'm gonna put this Z on a rotisserie And start cutting out all the rust and removing all the paint and under coating. this is getting to be bullshit....
Is there anything I should be worried about with it on a rotisserie? like idk the body crumpling up or something?
Old Nov 20, 2009 | 02:50 AM
If you can, mount the car to the rotisserie, using the bolt holes for the bumper brackets.
Old Nov 20, 2009 | 03:58 AM
Intrawebz Wizard
Well. thats simple enough.Do bad my engine stands aren't tall enough. Uh how much will it weigh with just the bare bones body. no glass or anything. If its not much I'll just fab up my own out of some pipe and angle iron
Old Nov 20, 2009 | 01:41 PM
thats what most people do.
Old Nov 21, 2009 | 11:31 AM
Intrawebz Wizard
Ah Well I'll do that when I get back
dammitmitchell
240Z, 260Z, 280Z V8 Swaps
Apr 4, 2013 12:58 PM
snwbrderphat540
197
Jan 19, 2012 09:32 PM
BoostL28
Feb 26, 2007 08:31 PM
Soup80
Sep 10, 2004 11:25 AM
jrobatl
Oct 31, 2002 03:02 PM
