turbo or bigger carbs
Old Oct 18, 2007 | 03:06 PM
tonsoffun300zx's Avatar
West Coast!
which would be better putting in my car a turbo or bigger carbs?
Old Oct 18, 2007 | 03:13 PM
entropy31's Avatar
The Cake Is A Lie!
turbos do not play nice with carbs, so unless you want to go to fuel injection, i would take turbo out of the equation.
Old Oct 18, 2007 | 03:20 PM
Turbo all the way. You can buy (depending on location) a 280zx turbo parts car for less than a set of tripple weber carbs. To make full use of those carbs you'll need a lot more work done to the head and exhaust. (and in the end, a stock turbo L28 running stock boost will still be as fast or faster)
Old Oct 18, 2007 | 03:56 PM
260zturbo's Avatar
Stupid Hurricanes...
blaaaaaaaaaaa dont do the whole bastering a turbo project....you will get another snw z. go ahead and do megasquirt and sds. it will make your life so much easier. might be scared in the start but once u understand it and what it does its piece of cake. but its up to you.
Old Oct 18, 2007 | 08:47 PM
didnt we already go over this? AND MY Z RUNS FINE, its teh stupid attempt at the N42 thats got me down now, and i had to re-tap my head cause i woulda kept blowing exhaust gaskets. bastardizing. pff...
also we discussed in your other thread and came to the conclusion you need to do alot of studying before you turbo anything.
Old Oct 19, 2007 | 06:21 AM
260zturbo's Avatar
re-tap your head? why where u blowing your head gasket so much? where u properly tq down your head....did u check to see if needed to be shaved? we pick on you snw b/c its just easy and convenient.
Old Oct 19, 2007 | 08:40 AM
i only blew one gasket but it was within only a few hundred miles. and it was because i had a broken and frozen bolt in the head, the one ALLL the way on the end so it left one exhaust port really unsupported. and it wouldnt come out, proke drill bits in it, broke and extractor in it, helicoils are crap so i just re-tapped it a slightly larger size.
Old Oct 19, 2007 | 09:45 AM
duowing's Avatar
NisTuner
That's the reason why I re-did my exhaust/intake gasket was to fix that broken stud.
Christiankustom
Feb 10, 2013 08:56 AM
rjsang
16
Aug 19, 2012 09:43 PM
vrocious
Jan 7, 2008 07:51 PM
kevtt
25
Oct 17, 2006 02:18 PM
OlderThanMe
Oct 4, 2005 02:39 PM
