Transmission Oil Change
Old Jun 9, 2003 | 11:26 AM
auxilary's Avatar
the Dude
1.5 liters, if memory serves, but that was for my 4 speed. Check haynes/fsm for information on a 5 speed. Or, do it the cheat way and fill up until fluid starts seeping from the fill plug. Fill plug is at the max level for the fluid.
procedure's simple. Jack up car (or drive it up on 4 ramps, it should be leveled). crawl under car, unscrew square nut on the side of the transmission, that's the filler plug. place pan under drain plug on the transmission, get a 1/2" socket wrench, unscrew, drain fluid completely, replace drain plug. Get 75w90 gear oil or castrol hypoid gear oil (80w90 works well too) and a pump for 3 bucks. start pumping. plug filler plug. drive.
total cost should be under 15 bucks
Old Jun 10, 2003 | 09:03 AM
preith's Avatar
I beleive most manufactures recommend a manual transmission fluid change about every 50K miles. Also, a pump is essential!
Virtuoso
Aug 14, 2017 07:32 AM
KaMIkAze
Dec 5, 2011 03:59 PM
Dante
350Z Performance / Technical
18
Jan 18, 2008 07:05 PM
tonylinc
Jul 5, 2006 12:42 AM
nynyny03
Aug 6, 2004 03:10 PM
