Tachometer on 280z stuck?
Old Apr 27, 2010 | 07:02 PM
McVick's Avatar
On my 280z, the tachometer is stuck on about 3500 rpm all the time, even when its completely off.
Any idea on how to fix this issue?
Old Apr 27, 2010 | 07:13 PM
theramz's Avatar
I have a present for you...
Even on the bench it would stay at zero. Probably burned out. Try disconnecting the battery in case it has a short to a positive source.
Old Apr 28, 2010 | 02:44 PM
McVick's Avatar
How do i even remove the tachometer? i take the screw off, but it still wont budge.
Old Apr 28, 2010 | 07:16 PM
McVick's Avatar
Nevermind, i just had to hit it enough times until it finally poped back to zero. Now it works just fine
Old Apr 28, 2010 | 08:43 PM
theramz's Avatar
Ah! The good old TV repairman trick! There are 2 screws, one in the top from the front of the tach and one on a metal tab on the bottom of the tach under the dash.
TedEZ
Nov 7, 2018 03:19 PM
TedEZ
Aug 26, 2014 02:57 PM
WildmaN
Apr 6, 2006 05:49 AM
NISMOGuy280
Sep 3, 2002 05:18 AM
