Quick Question About Valve Adjustment
Old Mar 17, 2005 | 10:47 AM
ZChief's Avatar
Red face Quick Question About Valve Adjustment
Hi All,
I feel like an idiot asking this because I've done this before, a long time ago, but here it goes.
Regarding valve adjustment, the book instructs you to adjust in a specific order, in two sequences (1st set of intake / exhaust valves and then then next set once the first set has been completed). Do you adjust them in that order with the cam lobe facing straight up at each valve (move the cam lobe so it faces straight up each time) or do you set the first valve to adjust (in both sequences) straight up and then leave the others where they sit?
Old Mar 17, 2005 | 10:55 AM
280Z4ME's Avatar
You need to set the first set so the valve is closed, lobe up. Then turn the cam with a ratchet and set the second the same.
Old Mar 17, 2005 | 11:34 AM
theramz's Avatar
I have a present for you...
Another way is to put the car in 4th gear and roll it forward untill the timing mark comes to "0". You can do half of the valves, which ones will be obvious ( lobe up). Then roll the the car till the timing mark comes up again and do the rest. The crank makes two turns per cycle.
Old Mar 18, 2005 | 12:50 PM
ZChief's Avatar
Thanks guys - I'll do it this weekend and report on Monday.
Cheers
fatman
Apr 19, 2012 08:38 AM
BlueKitsune
Jun 13, 2009 02:51 PM
RodMoyes
Feb 17, 2007 06:27 PM
gogriz91
Sep 29, 2006 10:02 AM
Soup80
Dec 27, 2003 10:33 AM
