old l28 and new stroker l28
nice. what are you going to use for EFI management? also, what block did you use and how much did the stroker build cost you? cause im still wanting to do one since i have an extra engine lying around but being in college im a little tight on $$$$ and i hear some high prices and some lows.....
This is a complete list of whats in it and im using the stock efi. Complete Rebuilt Long Block Includes...
P90 Head
3 Angle Valve Job
Stage 3 Performance Cam Set
F54 L28 Block
89mm Flat Top Pistons
240Z Rods
LD28 Maxima Crank
Competition Head Gasket
New Bearings
New Gasket Set
New Oil Pump
New Water Pump
New Freeze Plugs
New Timing Chain Set
Complete Reassembly/Machine Labor
Valve Cover/Oil Pan Included
Shipping
Coated 3/2 Header
performance exhaust
6 New Injectors
Flywheel
Inlarged Throttle Body
Cold Air Intake
im not sure exactly how much but it was about 4,600$ which is some what reasonable for the parts that were instaled. some may disagree but its gunna tare up the track so im content haha
P90 Head
3 Angle Valve Job
F54 L28 Block
240Z Rods
LD28 Maxima Crank
New Bearings
New Gasket Set
New Oil Pump
New Water Pump
New Freeze Plugs
Shipping
Coated 3/2 Header
performance exhaust
6 New Injectors
Flywheel
Cold Air Intake
new stock ones. The guy i had build it for me said the better thing to do would be to put a inlarged throttle body in with a cold are intake. he explaind it well he mostly said to have a dependable engine with the most horsepower this would be the way to go.
cant really tell on the picture but is that a hole on your from rail? if so i would be kinda iffy if had a 300hp engine in a car that has holes in its rails. would love some more info on this. just got a free l28 turbo block for my new build. just seeing what all went into your block. thinking of doing a stroker turbo.
i hear stroker turbo's render useless compared to stock bore turbo. plus they use a HUGE over bore for the 89mm pistons so adding boost doesnt sound good to me.
Look at Jeff P's Turbo stroker: http://www.angelfire.com/extreme/280zxt/
Anyway, nice work byrneZ!!!
The rule of thumb is 1 cc for 1 hp. So you should need 300 cc injectors. You will also need a different ecu. Might want to patch up that frame while it's out too. That old 4 speed and R180 diff won't last long. Nice looking engine.
im not really thinking stroker just boring the block out. since i want forge pistons boring out the block seems reasonable. i know a guy with a stroker turbo motor. his name is warren and its TRULY a sick motor.
Not "useless" but the weigh in between cost and hp may not be "worth" it to a lot of people.
