Ok Been looking for 3 days, time to ask
Old Oct 18, 2009 | 06:36 PM
Blue_streak's Avatar
Ok, so my engine is gonna need a rebuild. Just to much is going on with it. So it has a n47 head, which i read will then have a n42 block. Now my question is, can i put the p90 head on this block and turbocharge it safely? I have read so many differing views. Also, what would i need to do this? please help, i have used the search and i cant find the info i have been looking for. thanks
Old Oct 18, 2009 | 07:04 PM
Well this is a good first read: https://www.zdriver.com/forums/240z-280zxt-s30-s130-tech-tips-275/turbo-swap-ticking-people-off-since-2003-a-19638/
Do you already have a P90 head, turbocharger, and turbo exhaust manifold?
Old Oct 18, 2009 | 09:05 PM
I have a p90 head, turbocharger and turbo exhaust manifold
Old Oct 18, 2009 | 09:17 PM
Cool. Yep, the bottom end of the block is virtually the same. The turbo L28ET block uses lower compression dished pistons to allow for boost (boost increases compression ratio), and slightly different rings. But many have installed a turbo & run 6-8psi w/ no probs.
You will also need the turbo ecu (or aftermarket efi controller), turbo (or larger) injectors, oil supply to turbo, and turbo oil pan (or weld in a bung) for oil return. Those are the major things.
Minor things: gotta fab up a custom connection for the exhaust downpipe, & intake from turbo to throttle body.
Old Oct 19, 2009 | 12:22 AM
So in theory then i could get turbo pistons and rings for the N42 block?
Old Oct 19, 2009 | 07:51 AM
BoulderZ's Avatar
You can get stock, flattop, or turbo pistons and rings, in standard, oversize 1, and oversize 2 from MSA, Black Dragon, and probably even some of your local parts houses (good ones, not CheckerSchuckKragenAutoZone). Or even order custom, if you wanted. Note that the pistons are fitted to the con rods and pins by a very tight, heated interference fit. Get your machinist to swap the new pistons on to your con rods using his rod heater. Much simpler and cheaper than trying to fake it yourself, and he'll have your block already for hot tanking, and maybe boring/honing... right?
Have fun with the rebuild/mod! Perfect winter project.
cheers,
Dave
Old Oct 19, 2009 | 10:27 PM
Does a 76-77 280z have flat top or dished pistons?
Old Oct 19, 2009 | 10:35 PM
BlueKitsune's Avatar
Intrawebz Wizard
Dished
Old Oct 20, 2009 | 05:57 PM
So, i could use stock 280z pistons for a turbo motor then? The one from MSA would work good?
Old Oct 20, 2009 | 08:00 PM
skib's Avatar
This facepalm's for you!
you can use any pistons you want, just keep in mind the higher your CR the less boost you can run safely.
Old Oct 20, 2009 | 09:06 PM
Ok, thanks to all of you for taking the time to answer my newbie questions. I think i am almost ready to start my buying of parts, just have to wait to see what the block shop says about the motor. next question i have is, can i use the stock intake manifold on a 76-77 280z, and if i can are there any write ups on the piping? thanks
Old Oct 21, 2009 | 01:10 PM
Indeed. Lemme help ya out a lil
Clicky: https://www.zdriver.com/forums/search.php
raythenegr0
Feb 20, 2008 08:54 AM
flicktitty
May 7, 2006 09:57 AM
rob209
Jun 5, 2005 05:41 PM
AZ-ZBum
Dec 16, 2002 01:26 PM
