nismo 2 way LSD
Old Jan 8, 2006 | 10:04 AM
180sxidewayz's Avatar
Smile nismo 2 way LSD
Hi,
I have a JDM Nismo R180 2 way limited slip differential with axles.
This item was removed from a 1995 Nissan S14 Silvia with SR20DE manual transmission in Japan.
This differential has approximately 30,000 miles and it is in very good condition.
Applications:
Nissan 240z, Datsun 260, 280, and interchangeable with R160 on the Datsun 510.
Non ABS
Gear Ratio: 4.08
Pictures are available upon request
if interested let me know
located soCal
Old Jan 8, 2006 | 06:09 PM
Interesting... I thought S13, S14, & S15 had a diff pumpkin than the Z. Post some pics!
Old Jan 9, 2006 | 04:06 AM
the unit came off from jdm s14 with sr20de instead sr20det and it uses r180 intead r200
let me know your email address i will send you the pictures via email.
thanks
Old Jan 9, 2006 | 07:32 AM
thanks
nismopick@hotmail.com
Thanks!
Old Jan 9, 2006 | 01:31 PM
Just an FYI... That differential won't fit in a "pre-1990" Z without a ton of modifying... (either fab up a custom design, or use the rear suspension from the 240sx).
Lets compare: The S13 - S15 diff is shorter & fatter than the Z's.
S14 LSD:
280zx - Z31T diff:
Old Jan 10, 2006 | 07:53 PM
thanks for your info,
i didn't know they use different diff housing,
the seller who sold it to me told me that they would fit into the application i listed
do you know if you could just swap the lsd into z diff?
kidtsi
FS: 350Z / 370Z (03+)
Sep 19, 2011 09:40 PM
180sxidewayz
Jan 8, 2006 07:00 PM
nelsonz
Dec 26, 2005 02:54 PM
nelsonz
Dec 18, 2005 11:59 PM
1tuffz
May 15, 2001 08:37 AM
